found loose part in TH400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2005, 02:09 PM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
OK, while i was changing the filter on my trans i noticed that when i shifted the gears it made a notice that sounded like something was loose. it was this link that i pointed out with a red arrow, normally their is a bracket that holds this link down, i removed it, and when i did i heard something fall down on the trans (the second picture shows what it is)
now here is my problem: because i didn't see where that part went before i took of the bracket, i don't know were it goes?? and im sure that it's important
HELP
ID:	4965   Click image for larger version
Old 05-14-2005, 03:40 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
here's a blow up of a 400...joe
400 turbo
Old 05-14-2005, 03:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the part shown in the second foto is a speed-O gear clip. Holds the speed-O drive gear onto the output shaft
Old 05-14-2005, 05:28 PM
53LEDSLED's Avatar
here to learn
sorry but i don't know the name of all the parts. look at the new picture, are you saying that the part i pointed out with a yellow arrow is supposed to be touching the part i pointed out with red.
Old 05-14-2005, 05:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I never commented on the first foto or the parts in it. My comment was on the part that fell out shown in the 2nd foto...
The parts you are now questioning ......... that is the park pawl and the linkage/rod that activates it from the shift rooster at the valve body.
what else do you not understand? Do I mis understand the problem you have?
The part you removed held on with 2 bolts... only bolts on correctly ONE way. Be careful.
Does the parking pawl make clicking noises as you spin the output shaft? If so, the rod with the spring loaded end needs to be replaced/repaired. The end of that link rod is ROUNDED over to hold the slider on against the spring.
Often a pieece of the rounded over end of the rod breaks off. This allows the spring loaded slider to move OUT further than designed. Then the park pawl will click against the output shaft ring gear when NOT in park.
hope that is clear as mud.......
Old 05-14-2005, 07:17 PM
53LEDSLED's Avatar
here to learn
it's clear, but what i don't understand is that the piece that i show in hand is what i herd fall down when i removed that bracket.
Old 05-16-2005, 07:23 AM
53LEDSLED's Avatar
here to learn
problem solved, apparently when i messed around with the speedometer gears it must have fallen off without me noticing. when i checked the park pawl i thought thats wear that piece had fallen off.
im glad i checked that park pawl because it was missing a spring
thanxs firebird_red
I LOVE THIS PLACE
Loose Harmonic Balancer in 350 Hot_Rod_Faith Engine 2 07-03-2003 10:52 AM
2 Glowing Red ExHaust Pipes Part 4-(I think I found something !) white66coupe Engine 2 05-30-2003 03:40 PM
67 firebird th400 info speedfrk3 Transmission - Rearend 2 12-10-2002 05:31 PM
GM part numbers MI2600 Hotrodders' Lounge 2 11-30-2002 02:23 AM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 11:19 AM
