-   -   Found under vavle cover (http://www.hotrodders.com/forum/found-under-vavle-cover-231222.html)
Fang16 03-27-2013 11:06 AM
1 Attachment(s)
Pulled my valve covers to set the valves and found this laying next to a valve spring. Been about 2000 miles since I set the valves (solids) so it was time. Looks big enough to at least block an oil passage. Any ideas what it is and where it might have come from? It's not a ball shape, it' kind of tapered on each end. Hope the pic shows it well enough.
RWENUTS 03-27-2013 12:22 PM
Pushrod tip!!
68NovaSS 03-27-2013 12:48 PM
X2, never seen that before!! What brand are they...?
junior stocker 03-27-2013 01:34 PM
What engine is this from? I would tend to go along with a push rod tip, but have never seen one broken "that far" up. Is it "hollow with a lube hole? How's the engine running? You've definitely got some interest in what it might be. Could it be the result of being vandalized? Butch/junior stocker.
gearheadslife 03-27-2013 03:55 PM
PCV check ball
lmsport 03-27-2013 04:39 PM
I have thousands of those in my parts cleaning tumbler machine.
tresi 03-27-2013 09:11 PM
Hey neighbor, I'm another one that want to know if there's an oil hole in it. Perhaps a view from the bottom would help.
Fang16 03-27-2013 10:10 PM
Nope, no hole in it. All the push rods are ok. Could be from the PCV valve but it's ok and on the other valve cover so I'm thinking sabotage as suggested. Although I rarely have the front end open in public. Once at a car show last year and once at the strip.
33Willys77 03-27-2013 10:52 PM
X2 with Imsport. Sure looks like media for a tumbler. Is it stainless?
Fang16 03-28-2013 08:11 AM
Not sure? It's not that shiny, lol. It's very magnetic where stainless isn't that magnetic.
xxllmm4 03-28-2013 12:47 PM
1 Attachment(s)
I would give it a 95% chance its tumbling media. Tho not exactly the same this it comes in hundreds of versions.
BigMo 03-28-2013 01:03 PM
I agree, used to have one in a shop i worked in,,,,,,its a single piece of media from a tumbler
Fang16 03-28-2013 04:35 PM
Yep, that's it. Wondering now how it got in there. Towelheads? lol
Custom10 03-28-2013 11:21 PM
Fine example of why regular check-ups keep you on your feet, or in this case firing on all 8. good catch.
