Four Bar or Hairpins? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2005, 08:09 PM
Hello,
Im going to start building a '33 five window and I have been wondering weather to go with hairpins or four bars up front and parallell or triangulated in back. The motor is about 450 horse hooked up to a m-21 with a quick change, the gears will be 3:55-1 and 4:11-1
Im trying to learn as much as I can before going to the frame builder,
Thanks in advance for any help,
Old 10-18-2005, 01:11 AM
Pony's Avatar
Preference!! The hair pins have the old skool look the 4 bar the hot rod look. I think their may also be a small amount of caster adjustment with the 4 bar but i'm not sure. On the rear the triangulated 4 bar takes more work but works better and eliminates the need for a panhard bar. You should get HP Books "Street Rodders Chassis & Suspension" book. It will be the best $20 you'll ever spend. It covers everything you'll need to know on all your options, pros & cons and what to expect for cost of each option. They cover from a bare frame to a rolling chassis with the power train mounting basics too. It came out in 2000 so it's up to date and very well written. I love mine and use it regulary.
Old 10-18-2005, 08:16 PM
Thanks Pony, I was thinking about getting that book and now I willl for sure.
By the way its nice to meet someone from Wa. I use to live in Olympia,anyway thanks again,
Old 10-18-2005, 08:45 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Go 4 bar
The 4 bar suspension system is just do much better than the hairpins it is unreal..If you look under a new dodge 4x4 it is suspended with a 4 bar..GM is using the 4 bar under the rear of the new suv's..I stick with the panhard bar myself..
OMT
Old 10-18-2005, 08:48 PM
powerrodsmike's Avatar
Wiki Edits: 161
One thing to consider in making your choice is that it is less desirable to run a tube axle with hairpins. You are better off to run an I-beam with hairpins. Four bars can use either tube or I-beam. The reason is that the tube type axle doesn't twist as readily when 1 wheel moves up over a bump so in effect you create a really stiff sway bar. It can create a problem in that your batwings, rod ends or clevises wear out faster because of the added stress. I have heard of tube type axles breaking at the weld also. Although many folks run these on their car, I don't think I would want to build a problem in if I could avoid it. Just my opinion.
BE different....ACT normal.
Old 10-19-2005, 06:08 PM
Wiki Edits: 49
My sentiments exactly. Except I would put it stronger..... Never run a tube axle with hairpins.
Old 10-19-2005, 07:07 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Amen to all you guys....
Good advice... all the way through.
www.readershotrods.com drag cars/georges
Old 10-19-2005, 08:46 PM
walt's Avatar
You guys are right with one exception.
I am running a tube axle with hairpins and it has the mobility of a 4 bar setup.
If you look closely, I have installed a swivel bearing in the center of this tube axle.
Old 10-19-2005, 11:25 PM
Wiki Edits: 161
A swivel bearing in the middle of the axle. That sounds really neat. Is it like the fatman kit? I wish that the picture came through.
Old 10-20-2005, 12:15 AM
Wiki Edits: 161
Please disregard my last post. Wow! I just found the picture. As well as the others you posted on that exphose website. That looks like a 32 cab and a 29 grill setting on a super trick tube frame and a what the heck is that in the back to push that truck around? That front axle setup is way cool. How'd you do it? Would it work on a magnum style axle? Inquireing minds want to know.
Old 10-20-2005, 12:27 AM
Wiki Edits: 161
Ok so I spoke too soon again. go to walts homepage. Look at the 34 build pages. The answers are there. It won't be a wasted trip. Thanks walt.
Old 10-20-2005, 12:52 AM
xntrik's Avatar
better patent that damn good idea !!!!
Old 10-20-2005, 08:42 AM
walt's Avatar
Yeah..... I started the patent on it but it looks like it will cost a bit to finish. The bearing won't work with a magnum axle because of it's shape. It has a bow to it.
I'm running a mid engine 2.4 liter Porsche motor and 5 speed transaxle in the truck.
The truck is 48" high to the top of the roof.
Old 10-20-2005, 08:52 AM
Wiki Edits: 49
Now that's a great way to be different. No SBC there!
Not my particular thing but very nicely done.
4-link angle and bar lengths TBucket23 Suspension - Brakes - Steering 24 06-05-2005 05:31 PM
4 Bar que. 39chevy General Rodding Tech 3 10-18-2004 05:21 PM
Panhard bar revision 5window Suspension - Brakes - Steering 2 11-06-2003 04:31 AM
front sway bar mount location fire power Suspension - Brakes - Steering 2 05-17-2003 07:10 AM
rear sway bar DeathByGreaser Transmission - Rearend 2 02-07-2003 02:25 PM
