four bar question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2012, 09:35 AM
four bar question
given proper set geometry and correct tubing size what would be a consensus maximum length for the links in a four bar front end....advice and input appreciated .....thintin
Old 07-26-2012, 11:34 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
On the 4wd rigs the 4 bars extend to the center of the chassis to allow for long travel in the suspension..on an asphalt car they can be as short as a foot or so..so what are you building???
Does that give you an idea??
Sam
Old 07-26-2012, 01:05 PM
four bar questions
sam thanks for your input ......the build in question has a suicide style front axle.......not radical .....axle just ahead of the front crossmember and seems to have correct geometry in all respects......vehicle is fenderless(36 chevy cab)...the four link rods terminate on the frame at the firewall....42 inches long o.a......they are 1 inch dom tubing ... .250 wall.....with 5/8 's chrome moly rod ends........my concern is flexing under hard braking more so than everyday road use .......again i appreciate your reply
Old 07-27-2012, 07:18 AM
Wiki Edits: 27
sounds good
one inch should be strong enough, Most are only 7/8 dom.
Old 07-27-2012, 08:09 AM
Hot Rod Has Been
No problem that I can see...
Traction bar question Saito Suspension - Brakes - Steering 5 05-31-2012 10:01 AM
traction bar question Biscuit6447 Hotrodding Basics 7 10-12-2009 05:46 AM
Sway Bar Question J-Garden Suspension - Brakes - Steering 4 09-24-2009 06:23 PM
Sway Bar Question Retiredrich Suspension - Brakes - Steering 3 03-01-2007 08:02 PM
Roll Bar Question 79heavychevy Suspension - Brakes - Steering 2 03-12-2004 10:25 AM
