Four bolt main - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2002, 05:31 PM
Question Four bolt main
How can I tell if it is a two or four blot main?
Old 12-22-2002, 05:59 PM
Barz51's Avatar
a.k.a. Rusty Shackelford
Last journal entry: Another one
Post
Try looking up the casting numbers on a database, or pull the oil pan off and have a look.
Cory
Old 12-22-2002, 06:00 PM
4 Jaw Chuck's Avatar
Post
Pull the oil pan and then hold up your hand, retract a finger for each bolt you see on one of the center three main caps.
If you have three fingers left you have a two bolt main.
If you have only one finger left you have a four bolt main.
If you have no fingers left then you should have shut the engine off before removing the oil pan. :p
Outlawed tunes from outlawed pipes
Old 12-22-2002, 06:06 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
HE HE HE!
Old 12-22-2002, 06:50 PM
PrimeMover's Avatar
Sittin' on top of the world...
Post
Do like Barz sez, then go to; http://www.nastyz28.com/spmenu.html
Look it up - nothing to it.
