Four Wheel Drive Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 05:18 PM
Novaman78's Avatar
Kill It & Grill It
Last journal entry: New door panels
I believe this would be in the right section. My Mom owns a 1996 Mitsubishi Montero. The 4wheel drive works fine and everything but when your driving the 4 wheel drive indicator lights flash on and off until you shut the car off, then come back on when you turn the car back on. There are no weird noises or any fluid leaking. It locks in to 4 wheel low, and high just fine no odd noises or anything. Anybody have any thoughts?
Old 05-15-2006, 09:05 PM
Idicator light flashing means the computer has detected a fault of some sort. Could be as simple as a speed sensor.
Get someone to scan test the 4WD system to determine the code and fault
Old 05-16-2006, 09:47 PM
Novaman78's Avatar
Kill It & Grill It
Would Auto-zone be able to do that with their diagnostic machines, or is this something a dealer would have to do? If it is a dealer job does it have to be a Mitsubishi dealer or and service shop? The closest Mitsubishi dealer is about 50 miles away.
Old 05-16-2006, 10:39 PM
tnsmith10's Avatar
when will it rain???
autozone should be able to retrieve and clear the code... make sure u get the info on the code so u can get it fixed...
Old 05-17-2006, 01:38 PM
Novaman78's Avatar
Kill It & Grill It
Ok thanks for the help.
Question about drive shaft iceburgh Transmission - Rearend 3 01-05-2006 09:34 PM
All Wheel Drive GMC Van BigDawgsEatFirst Transmission - Rearend 6 09-28-2005 05:14 PM
TH350 Drive Question my350camaro84 Transmission - Rearend 2 06-10-2005 10:23 PM
Gear drive question?? HemmiGremmie Engine 9 09-02-2004 06:21 PM
how to tell if my 4 wheel drive works 1961_MGA Transmission - Rearend 14 01-30-2004 02:38 PM
