fram oil filter lower oil pressure - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-12-2006, 01:23 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by elvis 66 chevelle
I also plugged the oil by pass hole so all my oil has to go through the filter, so its important for me to use a good filter with good volume and flow ability. i believe i have proved fram filters give you less oil pressure.
Doug
Oil pressure is the RESISTENCE TO FLOW.
Lower pressure with a Fram filter proves it has LESS restriction in the filter media.
All oil pressure should be measured at the END of the system, not the beginning. Smokey Yunick said it and recommended minimum 15 psi idle and increase of 10 psi per 1000 rpm at the END of the system.
Your pressure is normal for a used Chevy, but too low. SBC are notorious for dumping oil out the lifter bores, while people worry about bearing clearances. Lifter clearance above .001 becomes a problem. .0015+ is horrible. Why do you think that racers bush the lifter bores?
Oil pressure sending units are available in different pressure values. Install a 12 psi and your light will not come on.
EDITED: Install your oil pressure gauge at the END of the gallery and see what oil pressure you really have. You will be shocked.
  #17 (permalink)
Old 09-12-2006, 01:42 PM
Irelands child's Avatar
Good reading
Originally Posted by 66Caprice
This link http://minimopar.knizefamily.net/oilfilterstudy.html shows a study somebody did that covers the insides of many brands of filters.
This is a real good read tho not conclusive as the author says.
Fram seem to be the puniest physically and have the fewest square inches of filtration media. Purolator has a lot of sq in surface area and Mobil 1 has a lot as well plus synthetic media rather than paper, but expensive. The Motorcraft seem good as well, and I will probably stay with them as long as I have a Ford truck and Escape SUV.
Irelands child
  #18 (permalink)
Old 09-12-2006, 01:48 PM
engineczar's Avatar
although the first statement is correct depending on where the gage reads the pressure the second statement is not. If the pressure is read at the port next to the distributor then it is being read after the filter and a lower reading indicates a restriction in this case.
  #19 (permalink)
Old 09-12-2006, 01:55 PM
xntrik's Avatar
I dare you to hook up your pressure gauge to the end of the oil gallery.
  #20 (permalink)
Old 09-12-2006, 02:53 PM
A friend of mine at Rousch Racing sent me this on his recommendation for oil pressure on our road racing motor:
How much is enough? The rule of thumb: "10 psi for every 1,000 rpm", was originated more than 25 years ago by Smokey Yunick. Does that mean that because you think your engine will run 7,000 rpm you need 70 psi?
No. Recommendations also depend on application.
Note: All pressures are "hot" (ideal temp is about 220 F)
Street engines 35-45 psi
Street HP 45-55 psi
Racing (only) 60 psi
Pro, turbocharged 70+ psi
In the 1984 Power Manual, Chevrolet recommends 65 � 80 psi for racing applications. This means purpose built, trailered racecars. Bob Mainetti of Canton Racing was quoted in Circle Track (April �96) as saying: " At 6,500, you want 50 to 60 pounds. At 7,500, 60 pounds is plenty of pressure."
  #21 (permalink)
Old 09-12-2006, 03:07 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Originally Posted by steve t
if you got a million dollars to use a product, you would use anything, but john is just a fast racer, hats off to him
Just cause the money comes from frame doesn't mean they race with hit.
I've got all kinds of sponsors that I don't use their products. They never said John, do you use fram filters? IF they do, it'll be a one application product that you can't get anywhere but john himself, much less any store.
  #22 (permalink)
Old 09-12-2006, 04:16 PM
Jmark's Avatar
Hmmm, interesting suggestion. I have my Frantz bypass filter plummed into the front galley plug just up from the end of the cam. Might have to undo it from the Frantz and hook up a pressure guage and see what i'm getting. Would be interesting to "T" it into that line with the bypass filter hooked up and see what happens too. The orifice in the Frantz is .035, always wondered what it did to the oil pressure. My guage reads 40 at idle and 55-60 at cruise.
Mark
  #23 (permalink)
Old 09-13-2006, 06:21 AM
elvis 66 chevelle's Avatar
66 Chevelle 406 SBC
Fram oil filter = lower oil pressure
My oil pressure gage autometer electric and warning light sending unit electric are installed on a T at back of block behind intake beside distributor on drivers side. my light comes on when oil pressure is below 18 PSI. So at 700 - 750 RPM'S in drive 17 PSI is ok??
  #24 (permalink)
Old 09-13-2006, 09:10 AM
Jmark's Avatar
I've seen them live on less pressure, but in all the sbc engines i've built, I've never had one idle below 30 pounds. Even my last one still was up good and it was just shy of 200,000 miles when I pulled it.
Mark
  #25 (permalink)
Old 09-13-2006, 09:15 AM
66 Chevelle 406 SBC
How do you get that much oil pressure 30 at idle???
Doug
  #26 (permalink)
Old 09-13-2006, 09:25 AM
17 psi is just fine at idle.
  #27 (permalink)
Old 09-13-2006, 03:31 PM
xntrik's Avatar
e."
Pardon me sir. That is partial mis-information and a misquote of what Old Smokey actually said.
I suggest looking up what Smokey Yunick wrote in HIS book about the small block Chevrolet.
He also emphasized that those pressure readings must be taken at the very END of the delivery system.
  #28 (permalink)
Old 09-13-2006, 06:01 PM
Don't ever, ever, ever use a Fram.
Fram Extra Guard
Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. It features cardboard end caps for the filter element that are glued in place. The rubber anti-drainback valve seals against the cardboard and frequently leaks, causing dirty oil to drain back into the pan. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time. The stamped-metal threaded end is weakly constructed and it has smaller and fewer oil inlet holes, which may restrict flow. I had one of these filters fail in my previous car. The filter element collapsed and bits of filter and glue were circulating through my system. The oil passage to the head became blocked and the head got so hot from oil starvation that it actually melted the vacuum lines connected to it as well as the wires near it.
Fram Double Guard
Another bad filter idea brought to you by your friends at Fram. The filter itself is a slightly improved design over the Fram Extra Guard, but still uses the same filter element. It has a silicone anti-drainback valve, a quality pressure relief valve, and enough inlet holes for good flow. The big problem is that they are trying to cash in on the Slick 50 craze. They impregnate the filter element with bits of Teflon like that found in Slick 50. As with Slick 50, Teflon is a solid and does not belong in an engine. It cannot get into the parts of the engine that oil can and therefore does nothing. Also, as the filter gets dirty, it ends up filtering the Teflon right out. Dupont (the manufacturer of Teflon) does not recommend Teflon for use in internal combustion engines. Please do not waste your money on this filter.
http://minimopar.knizefamily.net/oilfilters.html
  #29 (permalink)
Old 09-14-2006, 06:18 AM
66 Chevelle 406 SBC
Thanks for reply, i use fram on my my wifes car........no more! first used Fram HP-4 racing filter on my SB Chevy 400 because my son uses these on his race car. I had hard time getting mine off, header and flex plate in the way!! From my research the best filters are .....1 Amsoil, 2 mobil 1, 3 K&N, 4 Pure One!! The only other problem i have is a long filter is very close to header, can not get a finger between filter and header!! Do you guys have this problem?? Does it raise oil temperture or do damage to filter it self?? Do any of you put heat wrap on oil filter? That is what i am thinking of doing because i don't want to go with short filter.
Doug
  #30 (permalink)
Old 09-14-2006, 06:43 AM
The Smokey reference came with the text from Rousch. Perhaps you could enlighten us as to what exactly Smokey said, I read his book but I didn't memorize it.
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
Oil Filter relocation kit... jmbjs Engine 4 04-11-2006 08:15 AM
Oil Pressure gazrnr Engine 15 10-08-2005 01:43 PM
oil pressure sending unit? Brian Morency Engine 2 07-21-2004 03:43 PM
Speaking of Fram oil Filters Rad Ray Engine 3 12-02-2003 08:12 PM
