frame angles/measurements - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2007, 11:14 PM
frame kickup and angles
I would like the frame angles and the kickup measurements. I am planning on starting another T.
Thanks
vistin
Old 11-17-2007, 05:18 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders...best to ask over in the Hotrodding Basics forum. This forum is for introductions.
Old 11-17-2007, 07:05 AM
Thanks
vistin
Old 11-17-2007, 07:21 AM
cboy's Avatar
Last journal entry: Finished
[QUOTE=vistin]I would like the frame angles and the kickup measurements. /QUOTE]
Totally up to the fabricator. I've seen anywhere from 45 degrees to 60 degrees depending on the overall design. (I've actually SEEN 90 degrees...but highly questionable engineering on that one.) I don't know about others, but my theory is the frame should be designed in conjunction with the body, bed (if you have one), fenders (if you have them) etc. etc. --- and not the other way around, where the body components have to be adapted to a particular frame design.
Always learning...and sharing what I've learned.
Old 11-17-2007, 07:24 AM
kruzr's Avatar
street rods forever
If you look in Crankshaft Coalition Wiki (on this site)there's free plans there
hope this helps.
Sorry,wrong place,thread already started,dunno what happened,now I don't know how to delete.
Old 11-17-2007, 07:40 AM
poncho62's Avatar
Wiki Edits: 5
welcome......You said .."starting another T"............What angles did you use on the 1st one?
moving this to HR Basics.................
Old 11-17-2007, 11:50 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Best thing is to accumulate as much of the parts you are going to use then build the chassis accordingly..Sometimes doing it this way means that when one stumbles on a good deal he can bring it home for the rod project..Then the angles and measurements will become apparent..I have a chassis table that I built to accomodate my needs in this area..
Sam
Notched frame, did I weaken it?? KernCountyKid Suspension - Brakes - Steering 48 12-31-2006 03:37 PM
Frame mods dusterbd Suspension - Brakes - Steering 5 11-05-2004 01:00 PM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 05:54 AM
Custom Frame (Long) Toyman Suspension - Brakes - Steering 1 08-29-2003 09:43 AM
repairing a cut up frame jniolon Suspension - Brakes - Steering 3 04-12-2002 06:42 AM
