Frame/Axle Rust Converter and Paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2013, 06:43 PM
I am in the middle of a frame off restoration/repower of a Jeep Wrangler and have a situation I would appreciate some advice about.
I went over the frame with a wire brush on a drill motor to get off the surface rust then primed with a Rustoleum type primer followed (primer was aged for several weeks and seemed very hard) by a top coat of an equipment enamel paint.
The axles I used a rust converter product and then painted with the same equipment enamel paint.
In the recent hot and humid weather I am getting what appears to be rust popping through on both the frame and the axles. It appears to be on the surface with more of an issue on both the rough castings of the axles and the rougher frame areas (several new sections welded into the frame do not seem to be similarly affected).
Is this a symptom of my not getting enough coverage with the top coat of enamel?
Any recommendations how to proceed would be appreciated.
Old 07-09-2013, 06:06 AM
deadbodyman's Avatar
Wiki Edits: 11
could it be metal particals from wire wheeling or gringing sitting on top of the paint that simply started rusting? or is it under the paint? for instance the top of the axle would have rust specks but the bottom doesnt????
Old 07-09-2013, 05:43 PM
It seems to be on the high spots of the rough surfaces rather than the low spots you would anticipate might capture particles. I will try to determine if it is "under" the paint or voids in the paint next weekend when I get back home.
Old 07-12-2013, 08:48 PM
I am in the process of stripping the build up of crud off my 49 Ford 2 door frame. I am using the Eastwood frame kit with a cleaner before to get the grease and old oil residue off. It seems to be holding up well and really is worth the cost. It is supposed to seal in the rust and stop it. We used it on our last project a 73 Scout II and it is holding up well. We put it on over rustoleum an it didn't seem to mind and is about a year old and still looks great.
The Following User Says Thank You to olderthandirt2 For This Useful Post:
WICruiser (07-14-2013)
Rear window frame rust, windsheild rust cpratt Body - Exterior 5 09-18-2008 02:41 PM
Eastwood Rust converter kit Cobra06 Body - Exterior 0 06-04-2006 02:03 PM
phosphoric acid rust converter question zachscc Body - Exterior 1 11-10-2003 04:55 AM
Rust Converter - SEM Rob the blob Body - Exterior 1 06-26-2003 09:13 PM
not rust-rust STAINES on paint! Needm gone bullheimer Interior 7 02-04-2003 12:05 PM
