Hotrodders Bulletin Board
#2
re: Frame Boxing
I am sure that there are no kits available.
It all depends on how much stress you new engine etc is going to put on that frame. Your frame should be fairly strong on it's own, unless you have some "Monster" motor in there. Besides, it's kind of late now, right? |
#3
re: Frame Boxing
Right it is late, but I think it can be done. I just noticed while looking under the car that where the running board supports were bolted onto the frame, I did not put the bolts back in. The cross members are bolted to the frame at the same location. I will put the bolts back in ASAP. I wonder if that will give me more strength?
Thanks |
#4
re: Frame Boxing
The "X" member is what gives these cars more frame strength. Most of these frames are not boxed unless a real monster of a motor and a drag race rear end setup is used. But, be sure all the rivets and bolts are re-used. Many people cut into the X member for tranny clearance or mounting and destroy the boxing effect that the stock rivets and plates give. Then you get strange noises, doors act funny, hoods get crazy fit ( not that they fit good to start with).
#5
re: Frame Boxing
Street Rod Engineering out of Lake Havasau, AZ., has boxing kits. here Good stuff, I've purchased from them. Dan
Support free speech on our website, looky here:Lawsuit against our free speech |
