Frame Boxing Kit(s) AD Chev PUps 47-53 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2005, 05:10 PM
I saw on two different web site pre-cut frame boxing kits for both the front and read of my 49 CHev PU. Unfortunately I did not add sites to my favorites list nor can I track the history past 1 day.
Anyone know who has them available, they were between 50 and 75 for the kit.
Old 08-19-2005, 07:45 PM
willys36@aol.com's Avatar
Wiki Edits: 21
May I ask why you want to box that frame? Boxing is desirable on the flimsy '30s passenger car frames w/ big v-8s and fancy suspensions but those AD truck frames are already strong enough for a Sherman tank. Seems boxing will only cut off access to the inside of the rails.
Old 08-20-2005, 07:33 AM
To mount a MII front suspension I have to cut down into the frame to mount the shock towers. It is suggested by the Fabricator of the MII suspension Kit, Fatman Ind. that I box in the frame.
LD
Old 08-20-2005, 08:06 AM
Wiki Edits: 21
I see. Wouldn't it be easier (and cheaper!) to just cut up some 3/16" plate? Also, I would box just enough to accommodate the MII and leave the rest open. Plenty of strength to resist any flexing and leaves the thing accessible.
Old 08-20-2005, 11:56 AM
dinger's Avatar
Check these guys out, I used their parts on my coupe. Danhere
Old 08-20-2005, 03:38 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
I second Willy's suggestion. This is the route I took on my '48 AD truck.
Old 08-20-2005, 05:33 PM
Wiki Edits: 49
I used a Heidts kit which comes with the boxing plates.
This is as much as you need to box these frames for the installation of a Mustang II IFS.
Old 08-22-2005, 05:39 PM
Frame Boxing AD Chevy Pups 47-53
Thks for suggestions! Me thinks the 3/16 boxing as shown by Centerline will work just fine and should not be as much of a P inthe A as I first thought. FYI I finally did find the source for boxing kits, progressive automotive out of Ohio. They were one of the sources for who had MII type II front ends.
LD.
My todays search of the salvage yard for a rear end and rear suspension was not too helpfull for my 49 Chv PU work. I found an 80 firebird, but think 79 was the cut off for a simple conversions for a novice like me!
Old 08-23-2005, 01:49 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
The camaro/firebird cut-off year is 81. Anything after that will be too wide. The rear axle from the 80 is a typical swap for your Advance Design truck.
Old 08-23-2005, 04:52 PM
Rear Differential 80 Firebird in 49 AD PU identity help!
The Firebird diff. is difficult for me to ID. I ck'd sites and found codes but none seem to match the numbers on the case. What I found was a large "X"
a cast in number "0240" and a nine dots around what looks like an "8". It is definitely and 8.5 from the shape. However finding a numbr like 2pt, 2po 5po like some of the ID sites say is currently a mystery.
Old 08-24-2005, 04:07 PM
Houston54's Avatar
The axle codes are stamped onto the axle shaft tube. You might have to hit it with a wire wheel or brush to make them stand out. Sounds like you are looking at casting numbers which won't tell you much. If you cannot find the codes on the tube you will have to pull the rear cover and find out the numbers on the pinion gear. Dividing them will provide you with your ratio.
can I use an 80's blazer frame in my 54 Chev? In_Style Hotrodding Basics 13 09-13-2005 05:28 PM
350 chev in a 47 plymouth powerrodsmike General Rodding Tech 3 08-11-2005 01:58 PM
Frame to Rear Drum Brake Distance, '47 Chevy Fleetline djjc76 Suspension - Brakes - Steering 7 06-13-2005 01:53 AM
boxing frame on '33 plymouth sedan nomadbb Suspension - Brakes - Steering 2 03-27-2005 10:44 AM
47 chevy S-10 frame zonk Suspension - Brakes - Steering 10 12-29-2002 03:37 AM
