-   -   Frame Brackets (http://www.hotrodders.com/forum/frame-brackets-8871.html)
57Chevyman 01-08-2002 04:34 AM
Frame Brackets
I am geting ready to put my motor mounts and trans crossmember mounts in my '57. I bought the motor mounts and crossmember from Danchuck. They also sell the frame perches for the trans crossmember but they are nothing more than a couple of pieces of angle iron. It is going to take at least a 3" leg sticking in from the inside of the frame to provide a perch for the cross member. I was planing to use 3" x 3" x 1/4". In your opinion is 1/4" thick going to work out well for these perches?
Henry Highrise 01-08-2002 12:27 PM
I think that would work just fine, Should be strong enough. David Shands....................Retired Master Mechanic
57Chevyman 01-09-2002 04:08 AM
I thought so but sometimes it helps to hear it from someone else. I just could not bair to pay Danchuk's price of 13.25 for 2 pieces of 2x3x1/4 angle just 4" long. I paid less than 3 bucks at the hardware store. Build it yourself and save :)
