frame change - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2013, 03:44 PM
frame change
hey hotrodders, i have a 50 merc two door, it needs floor pans rockers and trunk floor, my question is i have a 96 caprice cop car ltl, would that frame and floor be made to fit under the merc?
Old 02-25-2013, 04:04 PM
poncho62's Avatar
Wiki Edits: 5
Maybe....I know its been done with tri five Chevys, but I think they are a bit wider....Time to break out your measuring tape
Old 02-25-2013, 07:07 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
As they say with a torch and a welder you can make anything fit.
Old 02-25-2013, 07:18 PM
I put a '49 Merc on a 69 Skylark frame using the frame. buick floor pans and firewall. Worked really well. If you start with a 4 door frame you will need to stretch it 4 inches. One thing is for sure. You end up with one sweet driving and riding Merc.
I don't know about the Impala but suspect it is pretty wide to use.
Old 02-25-2013, 07:31 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Lots of builders here are using 198o /1986 ??, impala ,caprice frames & floor pans the ones with small bolt pattern wheels , they fit very well.ride exellent if you want it lowered replacement drop spindles are cheap .dont know what years will fit but they are the square body style chevys the mercs, 1 is a 49 several are 51s ,hope this might help. also i guy has a 50 linclon on a 79 linclon frame with 460 he used floor pan engine trans,rear and interior ,it looks sane as a Mercury ,dont know if its the same or not.
Old 02-26-2013, 07:56 AM
Wiki Edits: 27
frame swaps
Most frame swaps are a lot more work than you think when you start. That Said, a Friend put his 49 Merc on an older Monte Carlo Frame. He said it was easy, wheel base and track width the same. you get disc brakes, power steering, A/C parts, But He chopped his own top, lowered the front bumper, made new sheet metal ftont pan, frenched it, etc. But he used to Work for Ed Roth, and is a good fabricator.
Old 02-26-2013, 02:06 PM
The early MonteCarlo is the same frame as the Skylark I used but the firewall is a bit further back. It the intention is to use the firewall and floorpans do some measuring to make sure it is not too far back. Also, I asume the MonteCarlo is a 2 door frame. If it is, it will have to be lengthened 4 inches more than a 4 door frame..
want to change frame HELP................. ronhow General Rodding Tech 7 11-06-2011 10:36 AM
change of plans in frame design matt167 General Rodding Tech 8 03-09-2011 05:58 PM
41 pontiac frame change Madmax20050 Suspension - Brakes - Steering 2 07-07-2010 11:48 AM
53 chevy pickup frame change robert forshee General Rodding Tech 8 01-11-2006 08:30 AM
body change to later frame streetrod936 Suspension - Brakes - Steering 11 12-15-2005 07:44 AM
