Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is this frame damage hopeless?
Old 03-11-2004, 12:23 PM
46_stvblt's Avatar
46_stvblt 46_stvblt is offline
One thing I know for sure, you can't weld rust. You will have to grind back to solid clean metal then add plate steel and weld it up. Especially time consuming if its difficult to get at. It can be done..Just take your time and try not to cut too much out at one time.....This would be a big liability for someone to take on but as others have said you could do it yourself.......GlennK
