Is this frame damage hopeless? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-12-2004, 08:49 PM
4 Jaw Chuck's Avatar
Some 3/16" plate and some hammer forming will get you some patches, if you can use a MIG welder your in business. I've also seen much worse. Make sure you patch only to clean thick metal to tie it all together. If you have a friend that is a professional welder with sheet metal experience, it will be a piece of cake.
Ever seen a car from Toronto? They last 6 years tops out there with all the salt.
— Han Solo
  #17 (permalink)
Old 03-13-2004, 06:14 AM
"How is the car in the frame area behind the rear wheels. Mich cars are usually gone along with both sides of the trunk."
Somehow its not completely rotten although #37 is behind or in front of (brain fart) the driver's side rear wheel.
"OTOH, if you welded and reinforced it yourself, it would probably work fine. "
The only problem there would be my complete lack of welding skills, experience, knowledge, and equipment
"Personally I'd get another frame. Not that hard of a swap and could be done in a weekend if the other frame had the running gear on it. What is bad is what you cannot see. It looks like the metal is thin along with being cracked. I wouldn't want to put time into it just to have it go bad somewhere else a few miles down the road. The car looks to be in decent shape so it would be worth sticking a frame under. You will also have less time invoolved by swapping one out. The safety factor is the biggest plus."
I understand this, but once again, I'd be having a buddy help me and I'd be paying him some. Plus we'd be using the rope to the ceiling method because we can't place the body on 2x4s because the rocker panels are pretty ready to go/rusty/weak as hell.
And really, I have a strange situation where I have a small service business (pressure washing) once the spring comes around, and demand is so high (sadly I underprice my services) that I can't devote even that weekend to doing it myself. The opportunity cost is too high.
I'm only back in the area of weekends and one those weekends, I have agreed for an extra few % on a big deck job, to get it done by x date, which means it and my family get my time when I'm back home, although the car is almost family.
So that is the only problem with a frame swap.
Plus the friend who would help me is a great guy, but I feel like unless I pushed and actually drove him to the car and stayed there every day, it wouldn't actually get done until next Christmas
"Think of it this way better to find out now then to find out at 80 mph!"
That is very true.
"Any good body shop will have a spreader to push that frame back into place. Yes, they might have you sign a release. As the spreader opens, the break gap will close almost to original. They would weld it and add a patch plate."
Wow, you made it sound so simple.
"Nice car, worth the effort."
It's got it's nicks and dings and problems, but overall, it's a great car.
"That doesn't look to bad I wouldn't hesitate to weld it up I've had many a car that had much worse frame damage than that when I first got it."
Noted. Thank you.
"According to your pics , the "split" that appears to be on top of the frame, by the A/C, could be repaired, depending upon the wall thickness of the area that is to be welded ."
It's still relatively thick around the a/c split.
"Pic # 37 on the other hand appears to be a major problem . It looks like that pc is beyond repair , w/the exception of cutting that section out & replacing it . When the metal flakes as shown in the pic , it is impossible to weld to ."
Yes, I don't know how that area got so bad. It doesn't seem to be anything unusual about where it is that would lead it to decay so much faster than the rest.
It would definitely have to be all the way cut out and replaced.
"If I was going to restore the car , I would put another frame under it . It just seems to be to much going on with the frame to try to salvage it"
There is a lot going on! I would LIKE to just do a frame swap, but like I said, while that is feasible, I don't think money and time wise it's my best solution *unless one of you fine gentlemen close to NW indiana want to take on the task for a little extra cash
"f the frame is in this shape, what is the shape of the under body, I.E. floor boards, trunk, etc. From what I see the car has serious frame issues but items that can be taken care of with a frame swap."
Somehow, the floorboards and trunk are still in great shape. No rusting through anywhere! I don't really understand, it's like some areas of the frame were dipped in acid and salt water their whole lives while others never so much as saw a day of salt before.
"ome 3/16" plate and some hammer forming will get you some patches, if you can use a MIG welder your in business. I've also seen much worse. Make sure you patch only to clean thick metal to tie it all together. If you have a friend that is a professional welder with sheet metal experience, it will be a piece of cake."
I have one last guy in mind who I'm going to ask. He works at Bethlehem Steel and might have some welding experience. But after that, I'm kind of up a creek without a welder.
Thanks for the replies everyone!
-Erik
And hi 4JawChuck!
Didn't see that was you. Winnipeg cutlass deal fell apart. He was a super guy to talk with (sent tons of photos, videos) but I just couldn't do his price or get him down to mine.
  #18 (permalink)
Old 03-13-2004, 09:10 AM
Hot Rod Hellion's Avatar
If you have a good frame handy, I would just jump in for the swap. How hard are frames to find where you're at? Those things arent too hard to find out here in Arkansas, and usually in pretty darn good shape.
Lotsa guys have repaired frames, but how good is the guy doing the fix? What are the chances of it breaking again somewhere else? I think piece of mind should be factored into the expenses. (not to mention, a frame full of scab patches won't help the resale value of a muscle car)
  #19 (permalink)
Old 03-13-2004, 09:46 AM
And hi 4JawChuck!
Too bad Erik, it looked good!
— Han Solo
  #20 (permalink)
Old 03-15-2004, 08:35 AM
Thom Laybourne's Avatar
ONE Last Thought
In the area of welding, look for some one that has a protable rig. Maybe you can exchange services. You can do some cleaning for him and he can weld for you. I did my floor pans and was all ready to do the welding. Found a guy in the yellow pages that did portable welding. He came ove to the house welded the pans and was gone in about two hours. And yes, I would still strip the front to get a better look at the work. Worst case you get some experience and then have the junk man take it away.
hr41pearl
  #21 (permalink)
Old 03-19-2004, 04:43 PM
I live in NY land of rsut and salt and rain and snow and rot and salt in the air from the ocean. My 1964 oldsmoble F-85 has two sweet holes in the frame--and you know what I am not worried i have driven many a rust buckets in my day--thats the fun of it-haha
