One more bad spot
![]() Looks pretty hopeless, huh? I've never had a car with frame damage, all I know is no one wants to touch em with a 10 foot pole. Probably a reason! You know, not wanting to drive a death trap and all. Wimps. Just kidding. |
Yes that crack can be fixed with a weld, then a cover plate welded over to strengthen up the area. In Michigan that would be a "PRIME" resto project! How is the car in the frame area behind the rear wheels. Mich cars are usually gone along with both sides of the trunk.
I think the only reason nobody wants to touch it because of liability issues. If you talked someone into welding it up for you, you could sue him later if something went wrong. OTOH, if you welded and reinforced it yourself, it would probably work fine. And when/if you sold it, you wouldn't know anything about no stinking frame damage. Just say something like, "I dunno, I bought it that way, you mean its not supposed to look like that?" Its a little thing called caveat emptor, which means, buyer beware.
One thing I know for sure, you can't weld rust. You will have to grind back to solid clean metal then add plate steel and weld it up. Especially time consuming if its difficult to get at. It can be done..Just take your time and try not to cut too much out at one time.....This would be a big liability for someone to take on but as others have said you could do it yourself.......GlennK
Personally I'd get another frame. Not that hard of a swap and could be done in a weekend if the other frame had the running gear on it. What is bad is what you cannot see. It looks like the metal is thin along with being cracked. I wouldn't want to put time into it just to have it go bad somewhere else a few miles down the road. The car looks to be in decent shape so it would be worth sticking a frame under. You will also have less time invoolved by swapping one out. The safety factor is the biggest plus.
Kevin |
You might want to look out west for a frame, CA. and AZ might have a rust free one that could be shipped to you for less than the repair of this one. I have seen them box weld a frame for a vette that was severly rusted out. When they were done it was stronger than original. Nice car I'd try and keep it going. Think of it this way better to find out now then to find out at 80 mph!
Regards Mark |
Spreader
Any good body shop will have a spreader to push that frame back into place. Yes, they might have you sign a release. As the spreader opens, the break gap will close almost to original. They would weld it and add a patch plate.
The other rust, looks like pictures of the TOE board area? Basically panel rust? Yes, you will have to remove everything forward of the firewall. Should be done anyway to check for other hidden problems. Something caused that and it was not normal driving. Once open you will get a better idea of what you are facing. Cost only time. Take lots of pictures as you take it apart. hr41pearl Nice car, worth the effort. |
That doesn't look to bad I wouldn't hesitate to weld it up I've had many a car that had much worse frame damage than that when I first got it.
According to your pics , the "split" that appears to be on top of the frame, by the A/C, could be repaired, depending upon the wall thickness of the area that is to be welded .
Pic # 37 on the other hand appears to be a major problem . It looks like that pc is beyond repair , w/the exception of cutting that section out & replacing it . When the metal flakes as shown in the pic , it is impossible to weld to . If I was going to restore the car , I would put another frame under it . It just seems to be to much going on with the frame to try to salvage it . 55mole |
If the frame is in this shape, what is the shape of the under body, I.E. floor boards, trunk, etc. From what I see the car has serious frame issues but items that can be taken care of with a frame swap.
