FRAME DEMINSION FOR 40 FORD PICK UP - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2002, 06:25 PM
Post FRAME DEMINSION FOR 40 FORD PICK UP
where can i find a schematic with the bolt hole locations for a 1940 ford pu? i need to check the frame to be sure it is true and need all the measurements i can get thanks 32racer
Old 10-28-2002, 05:59 AM
Post
Hi 32racer, the only drawing with dimensions I have located sofar is from www.wescottauto.com in the back of their catalog. It also tells you how to check your frame, to make sure it is square before you start any modifications to it. Hope this info can be of help to you
Old 10-28-2002, 06:08 AM
WoodsEdge's Avatar
Post
For some reason I can't bring <a href="http://www.wescottauto.com" target="_blank">www.wescottauto.com</a> up on my pc. Is that a correct add.???
Thanks, Jack
Old 10-28-2002, 02:39 PM
Post
link does not seem to work
Old 10-29-2002, 05:09 AM
Post
Sorry 32racer ! here is the correct web site www.wescottsauto.com , I for got an "s" or call them at 503 658 3183
