You might want to start off with some aftermarket rails. I did this on my '27 Ford Roadster Pickup. I purchased a set of American Stamping '32 rails and then form fitted them to the body, after which I boxed, bobbed, z'd and pinch them. Cross members, body mounts, boxing plates, rear air bag suspension were all designed and built by myself.
Basically I created cardboard templates to mock up the parts I need, transfer them into AutoCAD, and then either torch cut from plate or make the parts from structural angle, tube etc. Luckily, I am a designer and work at a manufacturing facility and have access to the equipment and materials I need. Whether you do the work yourself or farm it out to a fabricator, the body will need to be used as the template for the frame. |
I've done alot of drawing and peicing together with some Basswood as a little model, but my only question is how much do I need to notch the frame up front and outback to to get the desired ride height with the size of the rims and tires, I want the "cab" of the car to sit low slung but with the 20" rims i need to notch the frame, but I'm not sure how much or how to find out, I rather not do it My usual trial and error way.
I could easily design a frame for your car but kind of tough over the miles. place the body up on suports, the tires where they go and adjust them untill you get the look you are searching for. Once you get that accomplished you will be able to begin designing the frame. Temember cardboard and masking tape are your friends. If you do not have a cad system a good welder will no what to do with neatly made templates of cardboard or plywood (cardboard is much cheaper and easier to cut)
Good Luck |
Chevyman is right. The wheels and tire or atleast something as close to the combination you would like to run is one of the first peices to this puzzle. You will want to set your car up at the desired ride height with your wheels in place and then go from there. The way a vehicle sits is everything to me. I have seen some really sweet rides that because they look like they are riding on four wheel drive frames or have wheels that dont fit in the fenderwell properly look like crap. Set it up so you can walk around the car and so you can stand back 20 or 30 feet and try different heights ,rakes etc. You will be amazed at what even an inch of rake or lowered an inch will do for the look. Your driveway may be a good place to set it up, somewhere where you can test different heights etc.and have an long look at it.Good luck , it really isnt as hard as you think. Now when you get into setting the suspension up that can be a little trickier, especially if you dont buy an engineered kit for say kugel or someone like that. Have fun .Once you see your ride sitting the way you want, you will be surprised at how much energy you gain to get it finished.Take care.
P.S. I am in the middle of taking an AUTOCAD class as we speek, soon i may be able to help you out even more. |
Alright guys, I did what you said and set the body up on some 2x4's and set the wheels in their place and set the fenders in theirs, and I must say when I get this beastly Luxo-rod finished it should look pretty good at least to me anyway. My question is(yes the dreaded follow up)After I set all that up I measured where the rear end would go and where the front end(upper&lower a-arms) would have to be mounted but the thing that still bothers me is how much should I add for the air baggs for the rear, it will have a 4 link susp. Should I just add the height of the air baggs to what I already measured for the rear axel, will that give it enough clearance or do I need more?
Allow 3-1/2" clearance between the frame and the rear end housing. If the frame sits to high you may then have to "Z" or "C-notch" it.
Check out <a href="http://www.ridetech.com" target="_blank">www.ridetech.com</a> for air spring spec's and some helpfull views of four bar and triangulated four bar set-ups. |
