Frame Finish Ideas - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2007, 04:00 PM
Brett_PM's Avatar
ASE certified
Frame Finish Ideas
I have a 1987 Chevy pick up fram and i was wondering what your ideas would be on finishing it off. I was thinking either powder coating or Rhino Lining the frame. What are some of your ideas and have you tried either of the 2 i have mentioned. The truck will be a street/show truck. I still want to go 4wheeling in it so i cant have something that will chip easily.
Old 07-14-2007, 06:08 PM
Last journal entry: camaro clip con't 56 chevy truck
i would powder coat because it looks 10x better but if you just want something that wont damage then rino line. the powder coat can hold up to chips and such but if its going to drag rocks or anything of that sorts it will still scratch.
rino lining is ugly but its functional. i think you need to decide if you are more concerned with durability or looks.
paint is out of the question though if your going to put it through some abuse
Old 07-14-2007, 07:24 PM
Brett_PM's Avatar
ASE certified
i was leaning towards powder coating too. I dont plan to go over rocks to much so i think i will go with powder coating. I was just wondering what some of the communities thoughts were.
The next question is. The frame is currently covered with spray undercoating. Is there a way to remove that with ease?
Old 07-15-2007, 01:40 AM
Countilaw's Avatar
Cox Custom Cars
To remove undercoating, ummm "the dip" only other choice would be sand blasting.
Frank
Old 07-15-2007, 06:37 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
No easy way to remove undercoating tho I do lean toward a propane torch and scraping the residue..or it is off the the sanbblaster which is easier on you and not so easy on the checkbook..
I am leaning toward SPI epoxy primer and their bedliner product for those areas where I do need good durability and ease of repair..Powder coat we are finding has its place but in some cases is not all it is cracked up to be..
Sam
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
Notched frame, did I weaken it?? KernCountyKid Suspension - Brakes - Steering 48 12-31-2006 03:37 PM
frame pics willowbilly3 Hotrodding Basics 6 12-08-2006 10:25 AM
Help with the PREP of my frame?? Bud's 27 T Touring Body - Exterior 3 05-02-2006 08:43 PM
Frame Mod question johnnymopar General Rodding Tech 18 04-12-2006 06:24 PM
