Frame flexing maybe? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2007, 06:21 PM
I started a 47 chevy pick up project 11 years ago and got it on the road then had kids,new house ,yada,yada,yada. Well I have a question. I am running a 406 sbc that dynoed at 436hp & 459 ft.# torque. built turbo 350 trans & ford 9" 390 gears. Runs like a bear & a fast one.
I have an RB'S bolt in mustang 2 kit and a tranny crossmember. Other then that it is a stock frame. ( not boxed )
When I jump on it it feels as if the frame may be flexing under the torque ( to the passengers side) causing the truck to go left. I am not sure if this is from frame flex or if the rear is causing it ?
any ideas?
Old 01-31-2007, 07:27 PM
Flex...........
Ye gods a 47' Chev pickup with that much power......of course its' flexing especially if your getting some stick from the rearend off the line.
Have somebody else drive her for ya & observe for yourself.....You have probably seen it several times at the drags....one front tire is still in contact with the pavement, the other has ten inches under it!
Have it boxed & braced....can't hurt it & you'll probable feel the difference off the line first time.
______________________________________________Rick ............
Old 01-31-2007, 08:43 PM
opinionated old fart
Last journal entry: Sheetmetal
The frames on the AD trucks are weak and flexable, and over time the rivits in the cross members work loose, before we redid mine you could lift one corner of the frame 3 inches before the other side moved. Box and brace the frame, here is how we did mine.
Larry
Old 01-31-2007, 10:15 PM
Is that a 1st Series 47 Pickup with the rollout windshield, waterfall grille and headlamps on top of the fenders
OR
2nd Series 47 Pickup with fixed windshield, venetian blind grille, and headlamps in the fenders?
Old 02-01-2007, 06:22 AM
Thank you for your answers. The picture is great, that was my next question.
It is a 2nd series title says 1947 but I think it is a 48 or 49. Same body style as through 54.
Old 02-01-2007, 09:26 AM
The 2nd 47 trucks have one-piece door glasses and pull-down outside door handles.
The 51-up trucks have vent windows in the doors and pushbutton outside handles.
The 54-1st 55 have a curved glass one-piece windshield and a different grille.
The earlier trucks have a cowl vent that opens on the side of the cab, the later ones have a louvered panel for air intake.
Old 02-01-2007, 12:36 PM
yea the 47 gas tank is under the cab 48 they moved it to inside behind the seat. The 47 & 48 us a molding to secure the windlace to the cab 49's have channel the windlace fits in.
My trucks title is 47, but the gas tank is behind seat & has the channel for the windlace. so its any bodies guess.
Old 02-01-2007, 12:38 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
It is easy to blame the frame as twisting, and worth checking, but more than one factor enters into this.
Most likely you have a common case of "roll steer".
As the chassis torques to the right the "bump steer" toe in change of the front suspension causes the vehicle to steer to one side. Yes even on an independent suspension. Did you measure your bump steer at zero? I bet you didn't measure it at all. You just put the suspension in..... not all are good. (caster also alters bumpsteer. The more caster the worse the bumpsteer.)
With a leaf spring rear, roll steer is also caused when the right side squats under torque that spring arc gets longer and the left one gets shorter.... by a significant amount. That steers the rear to the right making the vehicle steer to the left.
You could also have too soft of rear spring eye bushings that are allowing the rear end to shift to an angle.
Tracking down this situation takes considerable effort. Making it all the more important to have done it correctly in the first place.
Old 02-01-2007, 12:40 PM
xntrik's Avatar
Originally Posted by CptKaos
So you liked that movie, huh??
Old 02-01-2007, 12:41 PM
I think it would be easier to change the drive train instead of trying to box the frame now with every thing else done.
Can the stock 47,48,49 frame handle a stock 350 250/275 hp engine?? the frame is boxed from the front horns to after the engine mounts.
Old 02-01-2007, 12:49 PM
hey xntrik.
Sure wish I would have talked to you before I did this project. I think I will check the bump steer first. The rear suspension is from a 69 ford galaxy 9". I will also have Posies look at that set up. Thanks for the advice.
Old 02-07-2007, 02:45 PM
xntrik's Avatar
Originally Posted by timwarren1@msn.com
hey xntrik.
You're welcome.
In #8 I said spring ARC, I meant spring RADIUS, since the leaf spring straightens out and gets longer the radius increases, and the other side shorter. 1/8 inch on each side is common.
If you need more help, you can PM me in case I miss a thread. (just like now a few days late)
Urethane bushings in the rear spring eyes and shackles will help tremendously and are NOT noticeably noisy or stiff.
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
Frame question Rufus_2 Suspension - Brakes - Steering 2 01-30-2007 09:52 AM
Critique My Frame STATUTORY GRAPE Suspension - Brakes - Steering 23 12-21-2005 08:51 PM
Cantilever system for air bags 53LEDSLED Suspension - Brakes - Steering 17 12-05-2004 03:26 PM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 05:54 AM
