Frame height revisited - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2009, 01:01 PM
Bob88's Avatar
Anyone have any thoughts on why this frame is so high. Even if I put three inch lowering blocks on it the bottom of the frame would still be 15" off the ground. Not sure what to do here, any thoughts?? Appreciate any help.
Bob
ID:	39315   Click image for larger version
Old 07-09-2009, 01:14 PM
ericnova72's Avatar
More for Less Racer
Because the isn't 3000+ lbs of body, driveline, engine, glass, etc sitting on top of it????
Old 07-09-2009, 01:19 PM
Bob88's Avatar
Yep, I thought of that too, just didn't seem like there would be that much weight too drop it down that far. Guess I need to wait till I get a little further along and see how much it drops. Thanks for the thought.
life is a temporary assignment
What year frame is it..What did it come out from..One reason it's high,Is there's nothing on it..You can zee the front.And if you have the room,Move the springs on the side of the frame..The older truck frame's was tucked way up under the trucks.They were high off the ground..
Once you put everything on it,It will still drop more a month later..
Old 07-09-2009, 02:04 PM
Bob88's Avatar
It's a 29 chevy coupe frame. I guess I'll have to wait and see how much it drops, then I can still add lowering blocks if need be. Thanks.
Old 07-09-2009, 04:33 PM
Conrad_AZ's Avatar
Ya Gotta Drive Them!
Last journal entry: Moved...
Actually, the frame looks like it is about the same height as the one on this photo of an original '29. Body sitting on the frame rails with the fenders and running boards channeled down below the frame rails.
The cars of that era did have, shall we say a high stance so that they could make it down the rutted roads of the day. Frankly, it looked like a truck to me as well!
From the looks of the frame, you are going to have some major fab work on it if you plan to put much of an engine in it, so moving the spring mounts might not be too big a deal.
You might try mocking it up by taking out leafs until the top leaf is nearly flat. That should give you an idea as to what it might look like at ride height.
Help with the PREP of my frame?? Bud's 27 T Touring Body - Exterior 3 05-02-2006 08:43 PM
Frame Mod question johnnymopar General Rodding Tech 18 04-12-2006 06:24 PM
Frame mods dusterbd Suspension - Brakes - Steering 5 11-05-2004 01:00 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
repairing a cut up frame jniolon Suspension - Brakes - Steering 3 04-12-2002 06:42 AM
