frame info - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2003, 09:37 AM
CARGUY's Avatar
frame info
does anyone know the track width [front and rear] and also the frame width on an s-10 i know they had different wheelbases.im trying to find an alternative to replace someone else's handy work
Old 11-19-2003, 01:46 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
frame on the s10 frame I'm using on a project is 40 1/2inches wide, the track width, well I measure center to center of the tires on stock rims & it was 54.... if you're working on a late47 to 1st series 55 the S10 frame will work.... here's a site on one http://www.usbody.com/Install%2047%20chevy.htm .....joe
Old 11-19-2003, 11:53 PM
CARGUY's Avatar
thanks for the info im trying to help a friend of mine with his project, a 47 dodge truck the the last owner put a sub frame in it and its not right .
