Frame Insulator Lower Need help FAST - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2004, 10:02 PM
Hey guys, I need your help once again. On my van a 1992 Tranpsort it seems that the lower Insulator has fallen/rusted off. Now I dont know how to fix it or even if I should be driving with it broken. 1) Can I still drive with it fallen off?? The bolt is still intact with everything else just the one insulator has fallen off. 2) How do I go about replacing it?? Do I just remove the bolt get the new insulator and a new bolt and bolt it back on?? Please I need your help. This is my only vehicle and well I have to work and everything so I must fix this asap. Thanks guys hope you can help me out!!!!
Old 09-09-2004, 11:00 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
You mention the bolt and everything else is there. What is everything else? Is just the rubber isolator missing?
Old 09-10-2004, 04:54 AM
yes the lower rubber is just missing. The upper one is still intact the lower one has fallen off.
Old 09-10-2004, 07:57 AM
I think there is a retainer that is below or a part of the isolator. It may have corroded away. Should be able to pick one up and replace the missing one. The bolt may be difficult to remove and in that case you may want to take it to your Pontiac dealer.
