Frame mounted alternator
I thought I would show the mockup. Since I am running solid mounts I decided to mount the alternator and power steerin pump to the fram so my engine will be clean and uncluttered.I will be using power cowl steering, open wheels and no hood sides. http://img.photobucket.com/albums/v4...lly/401008.jpg Last edited by willowbilly3; 07-27-2006 at 04:11 PM. Reason: pic |
Doc here,
Nice job! I would add one more thing to the system were it me... A STIFF Belt tensoner...Even though as you pointed out, it is solid mount, the frame IS subject to some amount of flex..a Tensioner would take up or relieve any change at the belt due to stress movement.. Other than that, a pretty Slick answer to SPACE (or lack of it) Problem! Let us know how it turns out Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Even with the solid mounts, wouldn't engine torque cause the engine to twist somewhat (chassis flex) causing the belt tension to change?
Just wondering...not criticizing...
KULTULZ: You and I must have hip "Post" at the same time!!! Doc
Looks good, but they also make low mount brackets for this reason as well. I have them on my 502. Just my .02 just in case the flex issue noted above becomes a problem.
Jason |
Hey Willowbilly,
Get your butt in gear and update your journal...looks like you've made LOTS of progress but no recent pics in your journal This is a very interesting technique...really cleans up the engine. I'm not sure I understand what "power cowl steering" is. Are you going to mount that pump on the other side of the frame the same way or does that mount some other way? I'm also intrigued by the notch in your frame for the spring. Can you shoot some more detail of that?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
yeah that..... git er done JB. |
Sorry I haven't updated. Here is a picture of the grill when I was whittling it down to size. And the pictures showing the frame notch. I built my own front cross member and welded it in at 7 degrees. It is welded to the frame around the notch on all three sides. Also I ran the frame boxing plates long and wrapped them around the inside corners of the cross member. Last edited by willowbilly3; 11-22-2006 at 01:20 PM. |
It really looks great....you are doing a god job.
Doc here,
Lookin' Good! Doc
| Frame mods | dusterbd | Suspension - Brakes - Steering | 5 | 11-05-2004 01:00 PM |
| Frame mounted Battery Box | Ronhel | General Rodding Tech | 4 | 10-19-2004 07:35 AM |
| Alternator mounted backwards | 66prostreet | Electrical | 3 | 10-14-2004 02:56 PM |
| Review of FatMan IFS Airbag install 1938 Chevy PU | Grashopr | Suspension - Brakes - Steering | 3 | 08-25-2003 11:16 PM |
| repairing a cut up frame | jniolon | Suspension - Brakes - Steering | 3 | 04-12-2002 06:42 AM |
