Frame mounted Battery Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2004, 08:00 AM
Ronhel's Avatar
Hello
Does anyone have a set of plans ( Sketches) to build a Frame Mounted Drop Out Battery Box.
Hate to buy one, & it would be a great project??
Thanks
Ron
Old 10-18-2004, 03:50 PM
Tazz
No I don't...
but I just had to say hello..I'm from Amherst Ohio....go figure!!!!
Tazz
Rat Rods Rule!
Old 10-19-2004, 06:10 AM
Ronhel's Avatar
Thanks for the hello Tazz.
Ron
Old 10-19-2004, 06:19 AM
EBlack36's Avatar
Rebuilt Excitment
I did not do a drop out box on the 36, I mounted it on the frame in the right fender. I used a universal unit that I got from speedway for about 30 bucks. Would be simple to fabricate though, use some angle to make a box that will fit the base of the battery, then weld a couple of runners to go up the side of the frame, then gusset it for strength, and finally some type of a hold down. I have been using this for 8 seasons of rod runs without a problem, but my car is full fendered and it is low so to remove the battery the car needs to be jacked up.
Old 10-19-2004, 07:35 AM
Ronhel's Avatar
Thanks
That is exactly what I want to do.
I am finishing my 35- 5 window coupe & behind the front tire seems like a perfect battery spot. Plenty of room.
I was thinking of the drop box just to ease removal when I store the car.
Thanks
Ron
