-   -   Frame mounted Brake System (http://www.hotrodders.com/forum/frame-mounted-brake-system-177190.html)
eheine20 05-01-2010 01:06 PM
Just looking for more info an this. Seen alot of people use them. Can you just buy the mount and attach your pre existing master and booster? Do you need to buy the whole system? Are they any good? Where/ who is the best company to go to?
Thanks
E.heine
ps. the system will go on a 47 chevy coupe.
Irelands child 05-01-2010 01:25 PM
Maybe then maybe not is about the only answer with the limited amount of information you gave us. What car do you have, where is the original mounted and where will you mount the replacement - firewall, floor, 90* under dash, etc.
eheine20 05-02-2010 11:52 AM
the original i believe was on the firewall, but im not sure. the car is just the shell and frame, 47 Chevy coupe. just exploring my options. Looking at what other do.
Irelands child 05-02-2010 02:59 PM
I would probably start here for the bracket/pedal mount: http://www.yogisinc.com/Detail.cfm/-...94/product.htm
For appearance sake, under floorboards, my opinion :D , would be your best choice. Firewall mounts tend to create working space problems as well as just plain looking cobbled up.
I hope you are going to at least use front disc brakes plus improve the rears as this vintage Chebbie really has lousy originals.
Dave W
matt167 05-02-2010 04:53 PM
'47 is factory under floor
Irelands child 05-02-2010 05:40 PM
Yeah and as is almost every car up 'til the '50s - and the option is to put it on the firewall as many folks will do!!!
eheine20 05-02-2010 10:05 PM
well, thanks for the info. Didn't know the brake system was under the car to start. Mine doesn't exist. as far as the brakes go. the conversion was done already. the car has a front stub off a 70 camaro and rear out of a Monte Carlo. Man i have a lot of work ahead of me.
