Frame mounted Brake System - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2010, 01:06 PM
Just looking for more info an this. Seen alot of people use them. Can you just buy the mount and attach your pre existing master and booster? Do you need to buy the whole system? Are they any good? Where/ who is the best company to go to?
Thanks
E.heine
ps. the system will go on a 47 chevy coupe.
Old 05-01-2010, 01:25 PM
Irelands child's Avatar
Maybe then maybe not is about the only answer with the limited amount of information you gave us. What car do you have, where is the original mounted and where will you mount the replacement - firewall, floor, 90* under dash, etc.
Irelands child
Old 05-02-2010, 11:52 AM
the original i believe was on the firewall, but im not sure. the car is just the shell and frame, 47 Chevy coupe. just exploring my options. Looking at what other do.
Old 05-02-2010, 02:59 PM
I would probably start here for the bracket/pedal mount: http://www.yogisinc.com/Detail.cfm/-...94/product.htm
For appearance sake, under floorboards, my opinion , would be your best choice. Firewall mounts tend to create working space problems as well as just plain looking cobbled up.
I hope you are going to at least use front disc brakes plus improve the rears as this vintage Chebbie really has lousy originals.
Dave W
Irelands child
Old 05-02-2010, 04:53 PM
Wiki Edits: 31
'47 is factory under floor
Old 05-02-2010, 05:40 PM
Yeah and as is almost every car up 'til the '50s - and the option is to put it on the firewall as many folks will do!!!
Irelands child
Old 05-02-2010, 10:05 PM
well, thanks for the info. Didn't know the brake system was under the car to start. Mine doesn't exist. as far as the brakes go. the conversion was done already. the car has a front stub off a 70 camaro and rear out of a Monte Carlo. Man i have a lot of work ahead of me.
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
Why frame mont brake master cyl 1931 steve Suspension - Brakes - Steering 7 07-03-2005 07:15 PM
Hydro Boost brake system BLOWN 1100 Suspension - Brakes - Steering 1 07-12-2004 01:23 PM
Should I keep my hydro-boost brake system? drlindz Suspension - Brakes - Steering 3 09-11-2003 10:38 PM
installing power brake assembly on model a frame straycat60 Suspension - Brakes - Steering 1 02-12-2003 05:44 AM
