frame mounts for engine swap?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2011, 12:18 AM
markzepp820's Avatar
Hello everyone, i'm posting for my friend... he has a 1964 chevelle malibu that originally came with a 194 cid inline 6. He wants to swap the 6 for a sb350 i sold him. We're having trouble getting this 350 in and lined up. It seems the SB motor mounts are too far forward and barely touch the crossmember to mount it. Are there special frame mounts we need to make this swap work??...or do we have to customize and drill new holes in the frame??? thanks,
Mark
Old 03-26-2011, 12:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You need to use V8 frame stands to mount the engine. The 6 cylinder stands won't work. If you have the correct V8 stands, there should be holes already in the X-member to bolt them to.
As a test, you can mount the motor mounts to the engine and hang the stands from the engine mounts then carefully lower the engine into position and if the stands are correct, you should see the bolt holes where they mount.
Then lift the engine back out of the way and bolt up the stands.
The stands will look like these:
Old 03-28-2011, 12:50 AM
Great! thank you cobalt327
1966 belair V8 engine frame mounts hefferzon Engine 11 09-28-2010 02:46 PM
Uh oh --390-332 engine swap mounts SDSJap Engine 11 08-18-2004 08:11 PM
Chevy II Swap - Frame Mounts, Etc... Delirious2000 Engine 6 03-29-2004 03:06 PM
Chevy BB engine swap motor mounts camarochas Engine 0 02-27-2004 09:15 AM
Engine frame mounts J. Cooper Engine 3 10-12-2003 09:09 AM
