Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Frame paint ideas; thoughts?
Old 03-28-2012, 12:29 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
If I were to do that I would use Corroseal on the inside of the frame..just use a siphon wand to fill the frame tubes with coroseal..yes you can weld up a lot of the excess frame holes..On the outside of the frame 2 wet coats of epoxy and a topcoat of tractor enamel and you are good to go..Shooting the paint is doable as it does not take all that long to do..a good warm day and it can be done in a days time and this may be a time when doing it and then saying sorry is in order on the painting..
Sam
