Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Frame paint ideas; thoughts?
Old 03-28-2012, 10:54 AM
Stick895 Stick895 is offline
Moisture is a tricky little bastard, it will creep in through the smallest opening. If you put rubber plugs in now, they might work but over time would probably leak at least a little. Moisture could then get trapped in the virtually sealed frame and therein lies the trouble. Trapped moisture is more damaging than moisture that gets in/out easier.
