Frame Hot Dip Galvanizing
I'm considering taking my frame, with everything removed (possibly even riveted pieces) to local Aztec hot dip galvanizing plant. Their process uses several huge tanks. First, it does ALL the prep work: cleaning, paint removal, grease removal. Then rust removal in acid bath. After acid bath, goes to neutralizing tank and then rinse. Final step the whole frame gets dipped in a huge tank of molten Zinc (and a couple other additives). It gets into every nook & cranny, including boxed sections, which must have holes drilled in them if air-tight.
Based on structural steel I've had them do, I'm guessing total cost of frame will be around $300, based on weight. Usual turn-around time is a few days. Then frame can be top-coated with whatever paint is desired, although painting would not be necessary for corrosion prevention. If anyone has used this process, or sees any problems I'm overlooking, please submit your comments & suggestions. Thanks. Guy |
frame refinishing
Beautiful work, Roger! Hope you have time to answer a few questions for a neophyte:
1. Size of compressor to use with the HF blaster? I'm trying to decide what size compressor to buy. As with everything else, it's $$ vs. minimum needed to get job done. If I use a HF pressure blaster like yours, based on your experience, what size compressor would you recommend? 2. What blasting media? I notice you have a tarp under your work area. Is this so you can collect & re-use the blasting media? 3. Size of hose and tip? 4. What have you done/plan to do as far as treating hidden, boxed-in parts of the frame against rust? 5. Any thoughts on pros & cons of hot dip galvanizing, as discussed in my earlier post? Any other advice & suggestions would be most appreciated. Thanks, Guy |
frame refinishing
Roger
The additional info on refinishing frame is a great help. I think I'm going to follow your method & materials. Thanks much! Guy |
hmmm...
The problem with coating bare steel with primer is, most primers are not waterproof. They're made to be painted. That usually means they're porous, so that topcoats can get a grip. If you put enough of a porous material on though, it takes a long time for moisture to make it to the steel. On a '57 Chevy I recently stripped to bare metal, the original factory baked enamel paint had allowed moisture to penetrate and start rusting the steel. Of course, that had taken over 50 years. The other problem is the seams. Powder coating, spraying, rolling all have the problem of filling in the seams. House painters use caulk to fill them. We have drip check and seam sealers. And then there's the whole inside of enclosed frame rails. What about them? Here is my suggestion. Blast the frame as clean as possible. Prime with a good epoxy or urethane primer. Seal the seams with a minimal amount of material. Spray with a good two part urethane topcoat. Then, after that has cured... coat the insides of the rails with something like 3M's Rust Fighter 1. Or something in a paraffin base that has rust inhibitors. Blasting completely clean stops existing rust. Primer gets into the pores created by the blast media. Sealing the seams stops moisture flow between the layers of metal at the joints. The topcoat should be waterproof if mixed and applied properly. And the inner surfaces will get a coating that seals against moisture. That inner coating can be re-applied periodically. Paraffin will disappear in time. This is extreme. It will require a lot of labor, but the material costs may be within the $600.00 budget. Just my random thoughts. |
Most epoxies are not UV protected however. But that is not an issue with a frame and suspension. SPI makes their epoxy in tintable white, gray and black. They started making their black UV resistant about a year ago. |
Got sidetracked by mechanical work on the beast, haven't done much with paint. Was about to order a gallon kit of SPI primer, then I picked up - for free - approximately 7 gallons total of Ben Moore industrial epoxy. I have no idea how old it is. Should I use it?
See if you can find a P sheet for the product to make sure it is designed for what you want it for. |
If you are planning on driving the car a lot, don't fuss with making it perfect. Brush or spray a good chassis paint over an epoxy primer and move on. Be sure to rotate the chassis in ALL directions and air blast it as you go to be sure all the junk is gone. If you are making a show car, then prep it like it was the body. But frankly, what good is the car if you are afraid to drive it and dirty up the chassis? Most likely you will only be driving it on dry days anyway! So, don't sweat the stuff you see very little of. Make it nice and clean and move on.
| Your thoughts on StarFire paint? | chappell | Body - Exterior | 3 | 05-06-2009 12:30 PM |
| Frame Finish Ideas | Brett_PM | Body - Exterior | 4 | 07-15-2007 06:37 AM |
| Wild cooling ideas - thoughts? | '67Pony | Engine | 17 | 11-12-2003 07:14 PM |
| FT360 .....ideas, thoughts, suggestions | Moby302 | Engine | 2 | 08-25-2003 03:14 PM |
| Build your own frame? Any basic thoughts? | Madd Syntst | Suspension - Brakes - Steering | 9 | 11-28-2002 09:00 PM |
