Frame rail question on 1974 Challenger - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2007, 04:48 AM
Has anyone here ever replaced a front frame rail on a '70-'74 Challenger? Just wondering what I'm up against. I've seen replacement frame rails that just slip over the old one, are these safe?
Old 10-16-2007, 09:52 AM
Wiki Edits: 49
They're safe if properly installed. Remember you're dealing with a unibidy car and the "frame" is really integral with the rest of the body. Using replacement rails that slip over the rotted out originals is by far the easiest way to go and is used extensively when restoring Mopar muscle cars, but keep in mind that the surrounding material (that you're welding the new rail to) has to be in decent condition for the repair to be any good.
Old 10-16-2007, 04:02 PM
I would think the top portion of the frame rail would be solid since all the crap inside the rail would sit on the bottom where it rotted out.
Old 10-16-2007, 06:56 PM
Wiki Edits: 49
Most of the time thats the case. However when the floors are rotted out sometimes the area where the frame rail is attached is rotted too. If its not and the top section is good and solid you shouldn't have a problem.
Old 10-16-2007, 07:27 PM
Mine is rotted in the area where the K-member mounts to. Under the car it's still solid.
Old 10-16-2007, 10:35 PM
Wiki Edits: 49
Then I don't expect you'll have much of a problem.
Old 10-18-2007, 06:03 PM
I'm still probably going to research it some and see what I come up with Thanks for the input
Tubbing rear with original frame rails? chieftain Suspension - Brakes - Steering 1 04-25-2007 08:02 PM
Frame Mod question johnnymopar General Rodding Tech 18 04-12-2006 06:24 PM
Frame powder coating color question. schnitz Body - Exterior 6 01-19-2006 02:42 PM
frame question? Lay'nFrame Body - Exterior 5 03-18-2003 08:27 PM
s10 frame question mitmaks Body - Exterior 7 02-04-2003 03:53 PM
