Frame re-enforcement
I got a 1970 nova and want to re-enforce the frame to prevent it from twisting. Reason is because the new engine cracks my tranny because the body twists just enough at take off causing it to crack. I've haven't done one on my own yet. Always had shop do it. I want to do my own on this project.
Thanks JD |
I am no experianced drag racer or something but this isn't making sense to me. The motor and trans sit on a sub frame, a VERY STRONG sub frame. They move with each other, something just doesn't sound right.
Where is the transmission breaking? How many have broken? WHEN do they break? Brian |
Brian, that subframe isn't so strong as you think back where the trans bolts up, the 4 body to subframe attachment points do quite a bit to keep this rear section of the subframe straight. This can get really bad when worn out bushings or rust gets into the attachment points and gets things rusted out.
Subframes like this are strong as hell whem welded into a street rod or old truck frame, but mounted on rubber they can get twist in them from the power put into the back axle twisting the rear of these frame horns in a unibody car. This is a known problem point with Novas and Camaro/Firebird. |
Brian |
Tail cracks
The tranny tail cracks. I have broken 2 of them. Only happens if I decide to gun the car. I got a dyno sketch build that rates block at 468 torque and actual torque from shop was 516 torque. I cracked (2) TH350's. My next one is a TH400 but want to stiffen the car up a little. I don't have slicks but I do have rims that are wider from the rear than the front ones. I got them as wide as I could get them.
You guys have a schematic for welding frame? Thanks, JD |
I believe it's possibly rear end spring wrap that is causing it. Is the drive shaft the correct length? Look and see if the yoke is bottoming out in the tail-shaft of the tranny.
Has the rear axle been changed? Is the pinon angle correct? I am not saying I am RIGHT, but you should be looking for what ever is causing this and not focusing on one thing. If the motor-mounts are all good (are they?) and the motor isn't moving a great deal then look at other possibilities. Brian |
Checked!
Drive shaft is an aluminum brand new and does not hit. Reaer end has not been changed or modified yet. The car didn't do this until this engine went in it. There is no noises or anything like that. I have brand new motor mounts and the are stiffer than the stock ones but not solid.
Ok, cool, did the drive shaft go in when the motor did? Brian |
What do you have to prevent spring rap?
Listen, you are building a hot rod and stiffening up the structure will be in the plans, that's cool. But for THIS problem, it sure doesn't hurt to look outside the first thoughts and see what you find. Brian |
Frame work done!
I did as you told me eric and no more cracking! Thanks a bunch!! I didn't do it all myself. I had a buddy come over and help me out. It was alot more difficult than I thought. Only thing now is the car spins tire on first 2 shifts. Is there a way to adjust this so I don't wear out tires so fast?
Thanks, JD |
Frame work done!
We welded on subframe support like eric suggested. I also went ahead and replaced the rubber mounts under the 4 bolts that hold the car together. The end part was the most difficult. My friend Mike and his friend Steven worked on the rear end area, and built a frame that keeps the car from flexing. They got the idea from a local shop and decided to give it a shot. As for roll cage I bought a kit from MT's Machine shop down here and welded it into place.
| Notched frame, did I weaken it?? | KernCountyKid | Suspension - Brakes - Steering | 48 | 12-31-2006 03:37 PM |
| Frame mods | dusterbd | Suspension - Brakes - Steering | 5 | 11-05-2004 01:00 PM |
| Body & Frame question | ruiner808 | General Rodding Tech | 7 | 09-14-2003 05:54 AM |
| Custom Frame (Long) | Toyman | Suspension - Brakes - Steering | 1 | 08-29-2003 09:43 AM |
| repairing a cut up frame | jniolon | Suspension - Brakes - Steering | 3 | 04-12-2002 06:42 AM |
