Frame to Rear Drum Brake Distance, '47 Chevy Fleetline - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2005, 12:45 PM
djjc76's Avatar
Hey Guys, I wanted to ask how far the distance should safely by between the back of my drum brake to the flange of my frame. I have an old 1947 Chevrolet Fleetline Aerosedan. I have the frame off; I recently installed a 1980 Monte Carlo rear end with the trailing arms because I am going to be running airbags all around. Right now, I measure the distance from the back of the drum to the flange of the frame about 1”. Is this too small?
I plan on running skinny 5.60 x 15” tires (or maybe 14’s) with big whitewalls. I just want to make sure the tires are nicely tucked into the fender and not rub on the frame or the fender/skirts.
Old 06-12-2005, 01:14 PM
How much clearance do you have with the tires on from the frame? Shouldn't have that small of a gap (at least 3 inches). For the brakes 1 inch is close but I don't think it would be a problem... Might have problems with the tire clearance though. I am using a 57 rear end on my 48 and it's got a little more clearance than that but not much much more just about an inch or so and I think it is around the same width as original rear. Is that rear end in the back on that pic the original one (I can't tell). If so then compair them.
Old 06-12-2005, 08:01 PM
S10xGN's Avatar
Gotta love a turbo!
djjc76,
I'm not trying to be overly critical, but that upper arm crossmember looks pretty slim! I'd be afraid any kind of torque to the rear axle will yank that puppy plumb out of the car. Lower arm mounts need more support, too. It might be OK for a parade car, but I wouldn't drive it on the highway like that...
Russ
Old 06-12-2005, 11:54 PM
djjc76's Avatar
Thanks for the replies...
S10,
the upper crossmember isnt done yet. I have to re-enforce it by putting "K" braces. The lower support brackets will get boxed for added re-enforcement.
SMF,
The rear end I used is an '80 Monte Carlo, which is 58" outer width and 51" inner width. The width of the frame from flange to flange is about 49". This only gives me 1" clearance from each side. I'm pretty much convinved this isnt the correct rear end. The axle in the background is the stock rear end, which meaures 61" outer width and 54.5" inner width. So, there is about 2 inches or so in clearance for the stock one. What I am planning to do is measure the rear end off a '70 Monte Carlo and hope that the inner width is about 53", which would give me about 2" on either side. Currently, there is no clearance from the tires to the frame, it rubs.
Old 06-13-2005, 12:48 AM
Yeah seems too close man. I would give it at least 3 inches of clearance for the tire clearance and try to get another inch and a half for the clearance in the brakes there. Your cross member there in the rear of the frame looks pretty skinny.... is that original? I know mine is like a 1X1 inch square tube one. I would try to strengthen that frame up too if you add a 500. I have a 48 chevy (same thing as your basically) and everyone said if I put a built up 454 in it then I should strengthen that frame because most of the weight is being held or used by that flat plate like thing under the boxed part of the frame.
Let me know how your project goes if you don't mind, I am hoping to get some more idea's for my chassis. I have a 57 rear end under mine and it fits nicely but not sure if it will take the power of a 454 haha. Probably will look for a nice Ford 9 inch with 31 spline and an N case instead of a WAR.
Old 06-13-2005, 12:57 AM
djjc76's Avatar
I am planning on adding a SBC 350 motor, 700R4. I will strengthen the 4-link braces, brackets, etc. I might go with a '70 Monte Carlo rear...it wil be a bit wider. I want to use 5.60 x 15 tires with the 3" whitewall (lowrider style). Like this:
Old 06-13-2005, 01:51 AM
Alright sweet, I see what your getting at now. Yeah well no worrying about that much clearance with that skinny of a tire now. Check out some tail dragger 47's and 48's... Here I will post a few for ya so you can get some ideas on it.
Name:	48 Taildragger.jpg
ID:	5388   Click image for larger version
ID:	5389   Click image for larger version
Old 06-13-2005, 01:53 AM
Here are a few others...
Oh and check out www.my48chevy.com
It has TONS of pictures of 47's and 48's and there are some really nice ones on there.
ID:	5391   Click image for larger version
ID:	5392   Click image for larger version
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 08:34 AM
chevy 3/4 ton rear drum to disc conversion Rob Keller Suspension - Brakes - Steering 33 12-03-2005 04:59 PM
Relationship between drum brakes and rear brake self-adjusters. jpd37 Suspension - Brakes - Steering 4 02-24-2004 09:13 PM
building a rear frame snub TooMany2count General Rodding Tech 2 11-05-2003 10:01 AM
rear drum brakes oldcarguy85 Suspension - Brakes - Steering 3 01-08-2002 09:41 PM
