frame rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2008, 01:08 PM
frame rust
Anyone tryed or know anything about Eastwood's frame and suspension restoration kit. You put the rust converter right over the "surface" rust, then apply the rust encapsulator, then the chassis black. Eastwoods has a good name but I'm a little skeptical about covering rust, even just "surface" rust. Whataya say?
Old 04-09-2008, 01:51 PM
i say sandblast it and get rid of the rust,it's not that expensive. you can probably have it sandblasted for the same price as that eastwood stuff costs. remove the rust or cover it up, which sounds better to you??
Old 04-09-2008, 06:12 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
X2.........
Old 04-11-2008, 10:29 PM
Rag top bird's Avatar
Hot rods are still the king
We sandblast all of our frames then epoxy prime and paint with Gm reconditioning black you can find it sometime hard to find but if you look on ebay you can find it http://cgi.ebay.com/ebaymotors/GM-BL...spagenameZWDVW
Old 04-12-2008, 08:50 AM
ortamenxs's Avatar
Avoid the Gremlins.
I am not a fan of rust convertors, hate the hard lumpy finish most of them leave, and if you sand you risk taking it back down to metal . Better to remove all the rust.
GM Re-black is good stuff, we can get here at the Napa easily I guess each are different (but try getting a power steering hose here). I never blasted or reconditioned my frame on my nova, but it had about twelve layers of ziebart or some kind of sealing thick dark gray rust inhibitor over it and on it to start . Don't' know why but it did.
Worked on a guy's car who had a bad frame rust spot behind the back tire on a chevy II ( surprise ). Both sides where rusted away, top and bottom where fine, just in one spot about an inch across, from top to bottom, the rest looked phenomenal, oddest thing ever. He used spray on rust sealant then painted over, but that one spot must of not gotten good coverage or something.
I welded two heavy gage plates on each side of the frame after removing the rust and used GM-Re-Black over them No problems since. But he wished he had removed the rust instead of sealing it after all was said and done.
I'd blast it, or (not feasible) soak it in rust dissolver for a week .
Good luck with it!
Old 04-12-2008, 10:14 AM
Marc Bitler's Avatar
I would agree with the other guys and say you need to have it media blasted to REALLY do a good job, but following blasting I would encapsulate the frame after that. There are a lot of rust encapsulators out on the market; Eastwood is, I'm sure, a good one. I used a product called POR-15 on my 40 Chevy frame and it's been 3 years with absolutely no deterioriation. I had everything media blasted. The entire car and frame cost me less than $400. Then I went over it with their Metal Ready (a spray-on product that kills any residual rust, then brushed on two coats of the encapsulator. All of those products will kill the active rust, and the encapsulator seals the metal from oxygen to prevent further rust. If there is active rust, just applying an encapsulator will not accomplish much, except to hide it for a while. I replaced the floors on my car with new sheetmetal, but still coated both sides with POR-15 and am quite satisfied with it. Just my two cents worth. Good luck.
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 12:08 PM
sub frame attachment Ricky Rocket Suspension - Brakes - Steering 4 09-18-2005 09:59 PM
Frame rust prevention 302 Z28 Suspension - Brakes - Steering 6 03-19-2004 06:33 AM
frame rust out. rhett General Rodding Tech 1 07-17-2003 01:36 AM
