Frame rust repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 05:09 PM
Last journal entry: More propane stuff
Frame rust repair
I finally had a little time to work on my Italia project. I have found some more rust in the car. It is in the lower part of the frame. This car's frame is made out of 4" box.
I was thinking of cutting the bad bottom sections out and welding in new plate. Anyone have any other suggestions. thought I would ask before I jumped in too soon. What do you guys think?
John
Old 03-27-2006, 05:13 PM
Wiki Edits: 31
is it a common car, if so just buy another frame, that is pretty bad rust.
Old 03-27-2006, 05:29 PM
No, it's not a common car. So cant find different frame. Another bad part is the body is welded to the frame so its going to be hard to fix. Good news is the tops and sides of the box are ok.
Old 03-27-2006, 05:58 PM
Wiki Edits: 31
support the sides good, and weld in a new patch, or just rebox compleatly over the exzisting. what kind of car is it? is it that little convert in your photo gallery? that looks kind of like a Fiat Spider.
Old 03-27-2006, 06:29 PM
adtkart@aol.com
Keep in mind that rust is a form of cancer, except it is contagious. If you do not cut it all out, it will likely come back to haunt you. Any metal that comes in contact with it will also have rust damage soon.
Best bet it to cut out all rust damaged metal and replace it with new, unrusted material.
Aaron
86 s-10 frame bent catscan4free Suspension - Brakes - Steering 3 03-27-2007 09:46 PM
New..have question about panel rust repair zimaad Body - Exterior 3 12-13-2005 10:40 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
Rust Repair Panels for a 1947 Oldsmobile 60Belair Body - Exterior 5 07-14-2004 05:06 PM
Rust damage repair oils65mustang Body - Exterior 1 04-14-2004 09:52 AM
