Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Frame Rust-trap
Thread: Frame Rust-trap
Old 01-04-2011, 08:31 PM
ant_8u ant_8u is offline
I was thinking of powdercoating the chassis and all the running gear - what do you think?
Could I get a finish at least as good as the red car shown above if I went with pc?
If I do choose pc'ing should I strip the inside of the outrigger myself prior to welding it in place?
I guess if I got it blasted there would be media stuck in the box section which could be a problem
Although, if I did weld up the holes in the outrigger first that shouldn't be an issue?.....weld up the holes, epoxy inside the box section, weld outriggers to mainframe, then get blasted and pc'd??
