Frame Rust-trap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2011, 05:19 PM
Frame Rust-trap
My '71 Triumph GT6 (like every other ever made) needs the chassis outriggers replacing
This part of the frame is a notorious rust trap
I think it might be down to how the outrigger is fitted to the chassis
It's a box section, with the vertical faces butt welded to the main chassis frame, and the horizontal faces overlapping the main frame
The main frame tends to rot through where the upper and lower faces overlap the chassis main frame
Is the rotting due to poor preparation under the two surfaces?
Could the overlaps be removed and all four faces be butt welded, or would this reduce strength too much?
The outriggers are located underneath the firewall, so need to have as much strength as possible
(I'll try to add a picture if possible)
Old 01-04-2011, 05:23 PM
Not sure if this picture is any good
Old 01-04-2011, 05:45 PM
I think the rust factor begins with the quality of steel used in the frame.
and ends with the way the parts are welded on.
If you're referring to the parts numbered 13 and 14 in your pic, I would think that they can be butt welded top and bottom. I guess they are attached with rosettes, or spots? that would allow water to get between the mating surfaces.
You'll need to do something about the tension, and compression flanges though.
Old 01-04-2011, 05:55 PM
Yep, that's it, parts 13 & 14
They're butt welded front and back and (I think it's called) lap welded top and bottom as the top and bottom have a lip which extends onto the main frame
The outrigger is a box section, but has holes running through it for the fuel lines
The holes obviously trap water, and sits in between the outrigger and mainframe where it rots through
I don't have access to my car to take pictures, but I'll see if I've got any on my phone which I can post
Old 01-04-2011, 06:11 PM
Old 01-04-2011, 06:19 PM
Old 01-04-2011, 06:23 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
is the rest of the frame ok ?
that looks pretty bad
Old 01-04-2011, 06:35 PM
The rest is just surface rust
Luckily that's not the chassis I'll be using, it's a spare I have, but it gives a good idea of what I need to prepare against
Old 01-04-2011, 07:20 PM
Old Fool's Avatar
Looks to me like it was untreaded metal, the front tires throw road salt into and onto the steel. Rust wins.
I would suggest cleaning all the rust you can get off the frame by blasting and or dipping. Then SPI epoxy to the interior areas of that outrigger, then weld shut those round holes then SPI epoxz the complete frame
Old 01-04-2011, 08:31 PM
I was thinking of powdercoating the chassis and all the running gear - what do you think?
Could I get a finish at least as good as the red car shown above if I went with pc?
If I do choose pc'ing should I strip the inside of the outrigger myself prior to welding it in place?
I guess if I got it blasted there would be media stuck in the box section which could be a problem
Although, if I did weld up the holes in the outrigger first that shouldn't be an issue?.....weld up the holes, epoxy inside the box section, weld outriggers to mainframe, then get blasted and pc'd??
Old 01-04-2011, 08:39 PM
Here are some images of the outriggers
I'll take some photos when I get to my car over the weekend
Note, the side facing downwards in the image will face forwards when fitted to the chassis
You can see only half of the outrigger is boxed in and there are holes at the top, bottom, front and back faces of the outrigger
Should I weld up these holes and reroute the fuel and brake lines, or should I fit grommets/bungs into the holes?
Thanks
Rear window frame rust, windsheild rust cpratt Body - Exterior 5 09-18-2008 03:41 PM
frame rust k.c. Body - Exterior 5 04-12-2008 11:14 AM
Frame Rust Beenawhile Introduce Yourself 1 12-24-2004 07:46 PM
BAD frame rust!! ezgoing General Rodding Tech 6 10-14-2003 03:20 PM
getting rid of frame rust Dubz Body - Exterior 5 08-10-2003 09:47 AM
