One hour setup time would be an ballpark to start and sounds like another hour should be enough for a pull . Are the fender to door gaps ok? Are they even and about the same as the back edge of the doors to body/rear door on both sides? Same with the hood etc? Is the problem with the bumper side to side or up and down? Got any pics? Rates vary from $45 to $85 an hour depending where you are.
http://www.a2zautoforums.com/showthread.php?t=1714 |
If it`s just the frame horns, it would be a simple pull.
Sideways or up and down,you could do it at home. If your worried about alignment take it to a frame shop, like Milo said a one hour setup fee and about one hour to do the pull, sounds about right. Good Luck Troy |
Frame Horns
It is only the Frame Horns. I just need to get the driver side frame horn straighten so the bumber will line up correctly. The bumper sits in on one side more than the other. I took the motor out of the car this weekend to shave the firewall and get the car completly preped for paint and interior. I just figuren now would be a good time to get the frame horn fixed...... Thanks for the info.......
Info
