frame swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2002, 03:31 AM
Cool frame swap
i have a 39 ford cp and would like to put a newer frame under it, any suggestion?
also looking for a 59ab block (complete) if you no anyone who has one and they don't think it is made of gold i would like to hear from them.
thank you. rcoleman@citlink.net
Old 04-01-2002, 04:47 PM
Don Meyer's Avatar
Post
Take a look at the Chev S-10.....Don
After reading the below post I decided to give you more info.
1. Placing a body on a different make frame is not recommended by street rod mazs, thus it might lower the value of the vehicle.(are they rite or trying to accomadate their advertizers?)They used to have acricles on these swaps.
2.Beside the above there is a growing trend to use the S-10 frames on rods. Its just plain cheaper & works in a lot of applications.
3. The S-10 frame is made to accomadate different wheelbases by the factory. The front of frame slips into the rear of the frame thus, by cutting the weld on both frame rails thr wheelbase can be changed.........Don
[ April 12, 2002: Message edited by: Don Meyer ]</p>
Old 04-01-2002, 06:42 PM
New Member
Post
[quote]Originally posted by ronald coleman:
<strong>i have a 39 ford cp and would like to put a newer frame under it, any suggestion?
thank you. rcoleman@citlink.net </strong><hr></blockquote>
well ,i don't want to dampen your enthusiasm ,BUT ,look in any of the rod books ,of the last month ,or last 20 years ,doesn't matter --- you wont find "any "frame swapped early cars ..truth is ,it just don't work ..any i have seen always have a problem with wheelbase ,stance ,appearance etc ..very frankly speaking ,don't try to re-invent the wheel ,look at the traditional styles , they work ..you will be better off using a more conventional chassis build up ,and be a lot happier when you are done ..good luck ,and best regards , jim prowse
Old 04-01-2002, 06:45 PM
New Member
Post
Old 04-02-2002, 06:43 PM
Post
Hey Ronald,you might refer back to a question posted by digger on feb. 5th. He asked pretty much the same question. I hope this is helpful.
S-10 frame swap for Chevy AD trucks mericketson Suspension - Brakes - Steering 11 11-17-2012 08:36 PM
49 chevy p/u frame swap krazytrain Suspension - Brakes - Steering 6 06-22-2007 01:51 AM
1949 Shoebox frame swap blacktoothgrin Hotrodding Basics 7 03-01-2007 04:22 PM
54 Chevy truck frame swap J.Ogle Suspension - Brakes - Steering 4 11-25-2003 07:56 PM
frame swap Scrooge Suspension - Brakes - Steering 13 05-02-2003 07:53 AM
