frame swap for 1950 chevy p/u - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-13-2007, 08:21 PM
Last journal entry: 1950 chevy 3100 P/U
I have done a little research on this and i have heard that you can swap a long bed standard cab 2wd chevy Sqo truck frame for the 1950 chevy truck frame. i was wondering if this is possible to do and if it is cheaper than grafting a nova or camaro front end. any help would be greatly appreciated.
Thanks
Old 08-13-2007, 09:28 PM
Wiki Edits: 49
Cheaper?? I doubt it. More work?? You bet. A Nova sub or Mustang II IFS is the best way to go. However if you're going to use your truck as a truck then go with the Nova over the Mustang unit.
Old 08-13-2007, 10:05 PM
Link to the s10 frame swap is in your other thread
Shane
frame swap? chevy13 Suspension - Brakes - Steering 2 02-19-2006 11:18 AM
1934 Chevy Master Frame mistermuscles General Rodding Tech 4 01-14-2005 12:50 PM
s 10 frame under a 52 chevy truck coyote069 General Rodding Tech 3 09-23-2003 08:04 PM
Chevy engine on Flathead Ford frame? senor_limpio Body - Exterior 1 08-20-2003 03:44 AM
