frame swap for 1950 chevy truck - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-11-2009, 03:37 PM
20 years ago I put a 1950 three window Chevrolet truck cab, bed, fenders,etc. on a 1983 Chevrolet short bed 1/2 ton truck frame. I had all the modern systems (suspension, steering, brakes, frame, and more). Remarkable, the dimensions of the 1950 truck and the 1983 truck were very close. I did have to weld on running board supports, and some other fabrication was needed, but overall it was a very simple swap with great results. The truck still runs and handles great, and repair parts are still readily available when needed.
I'm not really in favor of the S-10 frame swap because I think it's not beefy enough. That being said, I have many friends who like and have used the S-10 frame on many different projects, including trucks, without any problems.
  #32 (permalink)
Old 11-22-2009, 11:46 AM
1950 frame
Hi There, I Have A 1950 As Well And I Put A Camaro Front Clip On Ifs, Front Steer So Its 2nd Gen. Fully Boxed As Well. Like Other Replies I Read Based On Your Question, I Have To Say If You Have Access To A Frame Bench Or Are Capable Of Building Jig For Your Frame To Do The Work Along With Welding Experience, You Can Look Up Specs. And Probably Get Away With Doing It Your Self, How Else Do You Learn. Good Luck And Write If You Have Any Other Questions.
  #33 (permalink)
Old 12-22-2009, 09:33 PM
Originally Posted by fezz-man
I have a 1951 gmc on a 78 chev shortbox frame . The set up works well except that the front overall width from rotor to rotor is wider than stock. if you are lowering, you will have a real bear finding tires and rims that will fit in the fenders. Use a mustang 2 set up or get the shortened A arms from Fatman Fabricators. I wish I had, but with a lot of time looking for rims and tires, i just barely got my tires under the fenders. narrow rims and tires. works for me
do you have picture of your truck,
because i whant me to to put a my 54 cab on a 78 frame 1 tonne
  #34 (permalink)
Old 01-09-2010, 09:37 AM
1950 frame
you might try a old jeep truck frame go to classic cars they built a frame for the truck they restored last year
  #35 (permalink)
Old 11-28-2012, 01:08 PM
Yeller Truck's Avatar
I used my old frame with modifications with a corvette front clip and diff mount
  #36 (permalink)
Old 01-21-2013, 10:10 PM
My buddy did a89 s10 swap, and made it a daily For his son in one month, spent less than 3 Grand altogether
  #37 (permalink)
Old 06-24-2015, 01:06 PM
Frame Swaps
Hey Guys, I am new at this but I to plan on using a S10 Frame but I have a question? Has anyone ever used a Blazer frame. I plan on buying a 2000 Blazer that is running and using all of it if I can. I want the complete set up, air, auto, PS, PB, PW, Tilt and cruise. I plan on taking everything I can and putting in my 1950 3100. Then I am going to sell my 1950 running gear to help offset the cost. I just thought I would ask about the Blazer Frame. Any help would be appreciated, John from Alabama
  #38 (permalink)
Old 06-24-2015, 01:34 PM
2manytoocount/ You sound like me, I don't buy anything I can build. I was a certified welder and have a 30x60 shop full of tools. My question was about the S10 Blazer Frame. Can it be used or not?
John
  #39 (permalink)
Old 06-24-2015, 01:55 PM
I may be doing something wrong. Did anyone have a reply on my Blazer question?
  #40 (permalink)
Old 06-24-2015, 02:40 PM
ericnova72's Avatar
More for Less Racer
It's a 7 yea old thread....you may want to start your own thread to ask the question and get more results.
The Blazer frame is basically the same as the S-10 frame, they are both S platform trucks, about the only difference is where the gas tank is mounted and where the spare tire is carried.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1950 chevy swap to s-10 frame jason fitzloff Hotrodding Basics 6 03-10-2012 07:06 AM
48 gmc truck to s10 frame swap pioneer-auto Engine 1 06-03-2009 08:09 PM
chevy truck rearend swap OldSkooLNewbie Transmission - Rearend 0 01-18-2006 09:07 PM
53 Truck Frame Swap CHANCE1 Suspension - Brakes - Steering 2 12-12-2004 02:12 PM
1960 Chevy truck front disc brake swap importeater Suspension - Brakes - Steering 1 07-10-2003 12:16 PM
