frame swap
has anyone put a 47-54 chevy.p/u body on a 88-98 frame? THANKS
HOEHANDLE. |
Much too wide. I'v seen them on '73-'87 and '67-'72 chassis, but even those frames are too wide and look 'off'. The '88-'98 is even wider... If 4x4 is what you are after, than the Dana 30 front out of a Cherokee could fairly easy be fab'd onto the factory frame. If getting it lower is what you are after, than a Camaro/ Nova subframe will be way easier to get it there, and you could use all stock suspension for the Camaro/ Nova as you would set the clip at your desired ride height
| Recent General Rodding Tech posts with photos |
| 1950 truck frame swap to 1980's chevy frame | 1950truck | Suspension - Brakes - Steering | 25 | 01-24-2013 06:13 PM |
| frame swap | dsraven | Suspension - Brakes - Steering | 5 | 11-21-2010 08:54 PM |
| sub frame swap | canopener | Introduce Yourself | 1 | 05-08-2009 05:44 AM |
| frame swap? | chevy13 | Suspension - Brakes - Steering | 2 | 02-19-2006 11:18 AM |
| frame swap | twins_two | General Rodding Tech | 1 | 12-25-2004 08:32 AM |
