Frame Tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2012, 05:24 PM
Frame Tube
My 24 T Roadster was fabricated using L Tube, does anyone know wher I can purchase L Tubing? Need to replace sections Left and Right sides.
Thanks 22 Roadster
Old 12-16-2012, 05:40 PM
life is a temporary assignment
Thanks 22 Roadster
I never heard of L tubing.. Can you post a picture of it.. Or is it angle iron ??
Old 12-22-2012, 12:15 AM
Frame Rails
L Tube is 3 1/2" tall by 2 1/2" wide with 1 1/2" off sets and 6 mm thick,
24 Roadster
Old 12-22-2012, 06:25 AM
Wiki Edits: 27
Questionable material.
I had a co-worker's son who was just out of highschool. He bought a T bucket project that someone had started as a highschool project. The frame was warped and I said I can straighten that with a chain and a jack. A couple of the welds BROKE I told him he could cut it apart and grind and properly prep everything and reweld it. After an other swap of the project I ended up the 4 th owner and built a new frame from RECT .120 wall tubing, and Used a buick V6 and 5 speed. For something with a larger engine I like to go to 188 wall tubing. I was given a glass 23 T project and had to promise that when I get it done I have to take it back to Calif to give the guy that started it 20 years ago a ride. It was on a hacked up model A frame and I built a brand new chassis for it. Do you have any picts of the frame. ? ?
Old 12-22-2012, 08:43 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Home depot uses a similar type of material in its material racks. I wonder if the builder used some of that for the frame. There is a whole stack of that stuff at the local scaffolding company which is sold to people wanting storage racks for their warehouses..
Sam
Old 12-22-2012, 10:18 AM
I still never seen this before..Will have to look into this one..
Old 12-22-2012, 10:42 AM
I looked it up on google.. And this is what I found..
P shaped hollow steel tube/pipe,View P shaped hollow steel tube, Product Details from Tianjin Haiyunda Metal Material Co., Ltd. on Alibaba.com
Never seen this before now..
I don't know anything about this seller..I know this much,, They make shape's I didn't even know they made..
Old 12-22-2012, 11:42 AM
I don't like the looks of that "L" tube at all, I don't mean so esthetically, I mean structurally. It doesn't look well made with curved in sides, it looks like something poorly stamped out of sheetmetal for cheap production of shelves or something.
I see it as a very cool offering for some projects, don't get me wrong. But for a frame, first off it will add a LOT of work to figure out accurate cuts but honestly, I would stick to rectangular tubing.
Old 12-22-2012, 11:44 AM
Holy crap do they have some interesting shapes! Some of those could really come in handy for some artful fabrication.
Old 12-22-2012, 11:45 AM
Sam
You're right, that IS where I have seen it.
Old 12-22-2012, 12:21 PM
Wiki Edits: 3
Over the years I have seen so much of the use of salvage materials in the quest to save a buck that I am no longer surprised at much of anything..
Sam
Old 12-25-2012, 11:34 PM
P tube
I have seen that used for roof rails in long city type buses. I have also worked with it. Not what I would use or suggest for a frame.
Ben
Tube frame for PT Cruiser tlturbo Hotrodding Basics 2 02-27-2012 07:43 AM
Tube Frame for a 72 Nova Chris@whiterhino Suspension - Brakes - Steering 1 05-31-2007 03:29 PM
replacing a front unibody frame with a tube frame ? (bit long) lowROLLERchevy General Rodding Tech 5 04-06-2007 10:49 PM
32 frame from 6 in tube???? MustBnuts Suspension - Brakes - Steering 13 12-26-2006 04:13 PM
Tube Frame Parts johny chon Suspension - Brakes - Steering 0 09-19-2002 09:55 PM
