frame width - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2009, 01:09 PM
frame width
anyone know the frame width on a 73-77 el camino,monte carlo,malibu,grand prix.Or 77-85 lesabre,77-90 caprice?
Old 03-06-2009, 07:40 PM
327 / 350 hp's Avatar
Frame Width???
Hi phil, where do you need measures taken. I have 72 Chevrolet (full size frame) 327/350 hp
Old 09-26-2010, 01:42 PM
frame
hey im looking for a monte carlo/ elcamino frame to put my 66 short wide on. the only thing is i need the dimension of the frame
i need to know how wide it is frame rail to frame rail front to back. thanks
Old 09-26-2010, 01:53 PM
techinspector1's Avatar
Wiki Edits: 326
If you'll cut the '66 frame at the firewall and at the back of the cab and weld on front and rear clips from the G body, you'll be way ahead of the game. That way, you can set the ride height anywhere you want it without changing springs or lowered spindles or any of that other monkey motion that guys do who use the full frame from something else. If you don't understand what I'm saying, google "Z-ing" the frame.
Front track on the G body is 58.5". Rear track is 58.8". Measure your track center to center of the tires left to right to see how close the G body track matches yours.
Old 09-26-2010, 02:34 PM
well you see i have a slight problem with adding anything to my frame because i bought it off of some idiots that have cut and rewelded it and cut and now the frame is rotted out in places and i have found a early 70 model monte carlo and the wheel base is the same. i was just wanting to use the whole frame. then i wouldnt have to reconstruct a whole new frame. would it work. i know i will have to construct body mounts but thats slight compared to where i am right now on this original frame that has torsion front suspension and a rotted rear suspension
Old 09-26-2010, 03:21 PM
ericnova72's Avatar
More for Less Racer
The car frame is quite a bit wider than the truck frame, at least the section between the firewall and the rear wheelwell is, probably a foot to a foot and a half wider.
Entire car frames don't swap under trucks well at all. What about using the car front frame stub, then make your own from there back out of 2"x4" tubing??
You will have a hard time fitting the coil spring car rear suspension under the truck bed also, due to the high center crossmember for the inner upper suspension links. '66 truck has a great rear suspension already, still in use in NASCAR, maybe salvage it and install it to new fabricated frame rails??
That truck arm rear suspension is being sold as a performance upgrade for cars by a company called Hot Rods To Hell
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 09:24 PM
Frame mods dusterbd Suspension - Brakes - Steering 5 11-05-2004 02:00 PM
41 Dodge PU frame swap StPat5837 General Rodding Tech 4 10-23-2004 08:06 PM
57 chevy frame alignment question... please help! Sanspants Suspension - Brakes - Steering 1 07-20-2004 11:15 AM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-26-2003 12:16 AM
