frame work - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2007, 03:31 PM
frame work
i'm not exactly sure if this is the rite forum for my question but there isn't one for frames i'm sorry if i'm posting this in the wrong place well here it goes i'm building a 91 f-body camaro which is a unibody i want to build a frame under it so my car don't twist under the large amount of hourse power has anyone here done it before, or know of any good weld spots to install it since it was never ment for a frame theres not much room under there to bend and weld to anyone have any ideas for my build?
Old 05-15-2007, 07:00 PM
Vortech 4.3's Avatar
jack of all trades
they are called "subframe connectors" . search that on SUMMIT RACING.
you buy them and weld them in. though i think some can be bolted in. welding is better.
Old 05-15-2007, 08:19 PM
i'm gonna be putting some power out of the motor down the strip and was looking into putting a "frame" in between the subframe to help stabilize from twisting just dunno if i should weld them in to the subframe or try and find a way to go all the way down the car with them from front end to rear end
Part-time customizers need advice Dreadlord Garage - Tools 37 04-08-2009 05:58 PM
28 body doesn't seem to fit the frame oldguy829 Body - Exterior 17 11-28-2007 03:39 PM
First Body and frame split. Thoughts on "least damage" schnitz Body - Exterior 9 05-07-2007 12:22 AM
sub frame attachment Ricky Rocket Suspension - Brakes - Steering 4 09-18-2005 10:59 PM
updating '46 plymouth front end--subframe?? moparfect Suspension - Brakes - Steering 2 08-14-2005 08:42 PM
