frame work - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2013, 08:54 AM
frame work
Hello
The frame is from 3/4 ton chevy pickup I am c notching rear boxing in wth 3/16plate . want to replace original cross members with sq. tube the frame measures 2 1/4" x 5" tall tapers of course smaller to rear of frame. Do I need to box entire frame ? Also I want to shorten 10 inch for shorter box, any thougts on that ??
Larry
Old 01-29-2013, 08:37 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The 3/16" plate is appropriate for the boxing plates, and boxing the whole frame can be done but is not mandatory.
What you might think about doing in your "C" notch is to weld in the "C", add a doubler plate over the "C" that welds to the top and bottom plate of the frame, and then box it in. The box really only needs to extend 10"-12" forward and rearward of the "C" if you are not fully boxing the frame. Typically the boxing plate will be long enough to catch a crossmember that can be used for an upper shock mount as well.
Any other boxing plates need only to be installed where you are adding a crossmember or where you are sectioning the frame. More than that is just a whole lot of work for very little structural gain and more weight. I would probably section the frame in the area that a crossmember will attach to just for additional strength.
Adding an "X" brace in the center of your frame adds much more torsional stiffness than lateral crossmembers alone, and they can be built to accept the rear transmission mount.
Happy welding,
Andy
TIme for frame work.. Adding new half frame PureC4 Suspension - Brakes - Steering 1 08-20-2011 12:43 PM
will this frame work azbryan General Rodding Tech 3 10-30-2007 07:28 AM
frame work camaroboy1991 Body - Exterior 2 05-15-2007 07:19 PM
frame work Bojak Suspension - Brakes - Steering 3 10-01-2006 10:46 PM
FRAME WORK chevys4evr Hotrodders' Lounge 2 08-24-2002 04:21 PM
