Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #31
Old 06-16-2008, 05:55 PM
Richardjc Richardjc is offline
to Crest 25
Just read your post. The filters are also old. As old as you can get. I've had them for almost 50 years
Old 06-16-2008, 06:43 PM
Crest25's Avatar
Crest25 Crest25 is offline
re: Frantz filter system, buy or not to buy?
Richard,
Yes, I've installed MANY of them. I actually sell them but that's not why I'm here. I have three on my vehicles and one on my tractor. I am one of very few who actually installs them for my local customers.
I have not heard of wrapping TP around the center post before installing the TP in the unit. Actually, I like that much better than the "O" ring procedure but when you compare how nice the Frantz TP fits on the center post and the low difference in cost, you probably would not use toilet paper again.
After this explanation I hope I'm not offending anyone or sounding like I'm pushing the product.
Old 06-17-2008, 09:43 AM
Jmark's Avatar
Jmark Jmark is offline
HR moderator dude
Originally Posted by Crest25
Richard,
Did you find any issues with the cardboard center tube being too large? I haven't found a toilet paper that fits nice and snug over the metal center tube in the filter unit yet. That's the main reason I use the TP from Frantz Oil Filters.
I note some users actually cheat by using rubber "O" rings around the metal tube to take up some of the space preventing unfiltered leakage.
Speaking on the newer model filters, you do NOT need to worry about the center tube being snug on the pipe. There is a ridge on the base of the housing that pushes into the TP and seals it up.
Using store bought Scott TP is kinda tough. It's a quarter inch wider roll so pushing it into the can, can be tough. It's also bigger around and you usually need to un-wind quite a bit to make it fit, but it does make for a snug fit.
Global warming is officially over! Now it's "global cooling!". Quick, hack off your cat, fatten up your carb and go light the fireplace! Help Al Gore keep is stupid Nobel prize!
Old 06-17-2008, 09:47 AM
Jmark's Avatar
HR moderator dude
This oil has not been changed in the engine for approximately four years and is just like new.
How many miles have you put on in 4 years? (yikes!!!)
If you are going to push it that far, you really should send in an oil sample to have it checked out. Conventional oil will rarely go more then 6-10 thousand before it's additive package begins to deplete.
It may "look" good, but be completely worn out and in need of a change.
Mark
Back to top
This discussion has been added to the Engine Discussions category of the Hotrodders Knowledge Base.
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Frantz filter system, buy or not to buy?"
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 104 11-13-2008 07:40 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
Is metal in the oil filter a bad thing? :( TurboS10 Engine 26 09-11-2004 08:33 PM
Exhaust system hangers - where to buy? ken47 General Rodding Tech 2 11-12-2003 02:20 PM
