Top thread or bobbin thread? The main thing that makes top thread fray is not putting the thread through the thread guide on the needle bar right above the needle. The thread flops around and goes down to the eye of the needle on an angle.
Also, if I remember correctly, you don't have the felt pad in place in the lower thread guide above the needle on your machine. That would help immensely also. I always put some sewing machine oil on the felt when I oil my machine.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
I've been using the thread guide right above the needle. I don't have that felt pad though (didn't even know one exists). Can I just fashion one? Essentially lay some felt or other fabric in there and lubricate it or is it not that simple? Also to show I'm not a complete lost cause, attached is my first bench seat made successfully on my machine this weekend before this new issue. Needs to be fit a bit better but overall I'm happy.
Yes, you can use a substitute for the felt, anything to keep the thread from flopping around, but get the real thing eventually.
135 x 17 is the needle system for your sewing machine, it is not the size of the needle.
For industrial needles, the size is expressed usually with two numbers, an NM number, which stands for number metric, and a two digit number that is the Singer size number. Number metric is the size of the diameter of the blade of the needle (the area above the scarf and below the shank) in 100ths of a millimeter. The higher the number the heavier the needle, and the heavier the thread that can be used with a particular needle. I use a 140/22 needle for most everything, but I also use a 110/18 needle for finer work. 140 means the diameter of the blade is 1.4MM, or 22 on the Singer size scale. 110 means 1.10MM diameter and 18 is the Singer size. You should be able to find needle sizes from 100/16 to 180/24 for your machine.
125/20 will work fine.
ive had this problem also , found it to be the underside of the foot that i had ordered from the usa , the edges where the needle passes through were still sharp , honed them down with a dremmel tool. ive also had it as dan says , too large a thread though a small needle. my toyota is a copy of the singer 111. ade
| Recent Interior posts with photos |
| another 4.3 tbi thread... | Billybong | Engine | 13 | 07-23-2010 05:52 PM |
| 207 Thread? | Coodeville | Interior | 1 | 07-20-2010 06:54 AM |
| New Thread | Russ Sanderlin | Introduce Yourself | 2 | 05-29-2007 09:21 PM |
| One more thread | Beenaway2long | Hotrodders' Lounge | 1 | 07-15-2005 02:57 PM |
| ads on thread | camaroguy_1967 | Hotrodders Site Suggestions and Help | 3 | 02-24-2004 05:50 AM |
