Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Free 327!
Thread: Free 327!
Old 05-08-2013, 09:24 AM
eighty2Bbody eighty2Bbody is offline
Originally Posted by vinniekq2 View Post
The 327 has a shorter stroke than the 305 so it wont like the 2.42 gears.The old heads wont like unleaded fuel. A stock vortec 350 is a much better choice for the Caprice as a DD. The 327 deserves to live in a lighter car that will be driven in a spirited way.The torque curve is higher up the rpm range than a similar 305/350.
If the engine came from a 65 Vette,grab it,Corvette guys will want that block and steel crank.If its a solid lifter engine its worth even more than the hydraulic.Is the carb a Holley or Rochester?
Its a Rochester 4 barrel hot air choke.
